Firewood Management
SolbergDave
MX5800HST w/LA1065 FEL, Bobcat forks, QH10, RB3784, BB3584, RTA1274
Jul 12, 2018
27
PHILLIPS, WI
There is an old saying, firewood warms you 3x!! Cutting, splitting, hauling. Moving firewood is probably the most underestimated work. You split it, haul that to a drying spot, haul smaller loads to the burn area, etc. Having a tractor definitely helps out, still alot of handling each piece multiple times.
I thought about this, looked around and came up with a easy, very low cost solution. I built firewood racks out of used pallets and scrap wood. Each rack holds a face cord, it takes me 10 minutes to build one, and my only real material cost is deck screws (I always have scrap lumber around)
The great this about this is I can take the rack to the wood/splitter, fill it there, move it to a drying spot, then when I'm ready to use it move it to that spot (Sugar shack, fire ring...) Of course it helps to have fork attachments!
SidecarFlip
Banned
563
My 'firewood' comes in 50 pound bags.... Biomass pellets.
nbryan
Jan 3, 2019
1,438
951
Hadashville, Manitoba, Canada
Solbergdave what do you think that rack weighs full of green firewood? I like the idea a lot, just don't know how full I could lift it with my b2650 FEL. Capacity 534kg.
Sent from my Moto G (5) Plus using Tapatalk
3,207
1,320
I have boxes I built like that, and with my B2920 I can handle around 1/6th of a core of semi dry hardwood. That’s an actual cord measurement, not a face cord which can be whatever you want it to mean.
nbryan
Jan 3, 2019
1,438
951
This chart lists my dry tamarack as weighing 3330 lbs./128 cu.ft. cord. So I'll be loading 1/3 cords max per lift given 534kg = 1137 lbs. I guess best I mount the backhoe on back for a good counterweight!
https://forestry.usu.edu/forest-products/wood-heating
As pallets are more like 40" not 48" wide, one of your racks full may be just about 1/3 cord.
I have some pallets to play with, definitely going to knock one together soon and I'll report back on the results.
SolbergDave
Jul 12, 2018
27
PHILLIPS, WI
So after I built the first one and started splitting some big chucks of wood, lifting them green, I was thinking....is the tractor going to lift this rack, the wood was heavy. So first one, at about 1/2 full plus I forked it up and lifted no problem, so I went for it. Not an issue. I have a MX5800 and the rack is 4x4 and I put 2 rows in it, one on each side, then fill the center with some random pieces that will fit. So pretty much a full face cord.
FYI I used to burn wood to heat the house, now any inside burning is wood pellets. But I do use alot for maple syrup, and then theres campfire wood.
Per the better half we make the most expensive syrup on earth, so trying my best.
motionclone
May 4, 2018
1,399
996
Maine
I found that the best tool for handling and dealing with firewood/fire tending is a teenage son :D
3,207
1,320
Yeah, but unless you keep turning out new ones, that’s a short lived solution.
SidecarFlip
Banned
563
Too bad none of you live close. I'm going to take down 3 big ash trees and chop them up and probably roast them.
motionclone
May 4, 2018
1,399
996
Maine
You do know at some point they grow up and leave you... then you'll be in for it! :D
Its already been settled when that day comes, (next year he is going into Navy) We are getting a propane furnace or maybe minisplits
twomany
B7200
Jul 10, 2017
793
139
Vermont
Now the fun begins
Red oak, two foot dia at the butt.
Cut ,Split, and delivered. Pick one ;-)
How do those big logs stick to the grass like that is beyond me! ;-)
John T
May 5, 2017
1,380
904
under a rock
I’ve got so many dead ash trees I will have firewood for years.
Cut some hickory slabs the other day
Just fer fun.
Actually wasn’t that much fun
Hickory is tough as nails.
6,328
nice lookin slabs ! hope you can sell them. I filled a 20'seacan with live edge,spalted Maple, most 1.25-3" thick, after 7 years I burned it all.NOONE even offered to buy it....
Now I'm up to my ash in Ash logs ( imported 'borer' is killing every Ash tree here in Ontario ) Seems every species has an attacker.
One 'problem' with a chainsaw mill is the amount of wood being cut compared to a bandsaw mill. 5 or 6 cuts probably equals one lost board ?
John T
May 5, 2017
1,380
904
under a rock
Oh yeah
If I did this more often,
I could go into the sawdust business
LoL
I probably won’t sell them.
I’ll just use them for projects in the future.
5,694
Hell flip your retired you could just fill up a tri axle and bring a load down here to the coal country,,buddy:D
John T
May 5, 2017
1,380
904
under a rock
Around here they put a ban on transporting firewood across state lines.
Too little too late
The damage is already done
