After getting an estimate on some fencing repairs, I have decided to settle for patching up what I've got. I want to put up a 2 x 6 top rail on a section that has woven wire on the bottom and an electric wire on the top. The deer and the falling tree branches are always messing up the hot wire. The 4 x 6 posts are in pretty decent shape and were supposed to have been put in 8 feet apart, but aren't, so there will have to be a lot of cutting of the boards. (Plan A, years ago was to work toward 5 ft unclimbable mesh horse fencing with 16 ft top rails, but not happening.) It is far enough from the barns that a battery powered circular saw would be easier than measuring first and cutting up in the barn and hauling the boards out there. Ground is hilly so some will need to be cut on an angle.
So what is a good choice in saws for this task? I have a couple of de walt things, and maybe the batteries would work, but easy to handle is a major consideration. Lots of after Xmas tool sales
Second, fasteners. I have drifted toward using deck type screws on recent repairs rather than nails, and have a battery powered drill driver set, but have problems stripping the heads of the screws, or if they are going good they disappear into the wood. (You can stop laughing now, I know this is a skill issue.
I would like to be able to back these screws out for easier repairs, but am not finding deck screws with the right sort of heads. (Usually drill pilot holes when stripping is a problem in some wood). So suggestions of brands with sturdier heads would be much appreciated, this is a long stretch of fence. Also any technique suggestions. I am borrowing my neighbor's 14 yr old son for a helper so I need to set a good example.
