FEL lift capacity problem
botafarmboy
Kubota b7300 FEL, Box Scraper
Jul 25, 2015
Watsonville, can, usa
I have a 1998 b7300 series tractor with an SMC 64Q fel, Gearmore 2g box scraper with rippers and a top and tilt control. I have only had this tractor for 3-4 months. I have noticed that if I have a full bucket of med density dirt, not compacted clay but not really loose fill. The bucket will not raise to it's highest position. It gets to about 75%. I parked it on some cardboard and ran all of the hydraulics for about 10 minutes and then checked to see if I had any leaks, there were none. I replaced the spin on filter and it had a factory service about a year before I purchased it. Looking for the next thing to check. Thanks in advance for suggestions.
Jeff
9,842
A leaking cylinder on an interior seal will cause a week lift or roll.
If you lift the bucket up weighted does it drift back down?
If not you could have a relief or pump issue not building enough pressure, you'll need to test pressures to know if that is the problem.
botafarmboy
Jul 25, 2015
With a loaded bucket, the bucket does not drift back down. As far as why I needed to lift that high, I was having to dump some fill on the other side of a tall fence to stop some erosion.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I understand wanting more lift, I do it all the time. It simply sounds like you have reached the limits of your machine. My B7100 wouldn't lift a full bucket of dirt either, not to full height anyway.
botafarmboy
Jul 25, 2015
According to the spec sheet on this loader, lift capacity at full height is 630 lbs. This is a quarter yard bucket which should put the weight around 500 lbs. So maybe things are getting a little worn and I should shoot for 3/4 when I am filling the bucket up.
bcp
BX2360
Apr 20, 2011
644
80
SW WA
Sometimes lift capacity is measured at the bucket mounting pins. 630 at the pins will be 500 at some particular distance farther out.
