K Kubotasidewalkdude New member Equipment L3940 HST Dec 6, 2016 43 0 0 Canada Dec 6, 2016 #1 How does one change the fan belt on an L3940 HST? Had a look at it yesterday as the belt is at max tension and almost done. Sent from my iPhone using Tapatalk
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,977 2,831 113 Bedford - VA Dec 6, 2016 #2 Kubotasidewalkdude said: How does one change the fan belt on an L3940 HST? Had a look at it yesterday as the belt is at max tension and almost done. Sent from my iPhone using Tapatalk Click to expand... First and foremost - find you a work shop manual, and or do research here. Also - on your other thread - I would inspect the cable on the E brake and lube it well.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,466 8,745 113 Sandpoint, ID Dec 6, 2016 #3 Unless I'm missing something it's pretty strait forward on that model: You just loosen the alternator and remove the belt carefully guiding it over the fan, then do the reverse to install. I would also recommend you getting the WSM (Work Shop Manual, AKA Service Manual), full of a ton of information.
K Kubotasidewalkdude New member Equipment L3940 HST Dec 6, 2016 43 0 0 Canada Dec 6, 2016 #4 It's not that easy. Although from what I'm reading it isn't to hard either. It's gotta be fished in some how after loosening a few bolts Sent from my iPhone using Tapatalk
