Engine Oil
oldudbob
NC
I recently purchased a used BX1870 that has almost 200 hours. I would like a recommendation as to what replacement oil I should use. My tractor will be used mostly in temperatures above 32 degrees. Should I use synthetic or non synthetic oil and 10W30 or 15W40 weight? Any particular brand of oil?
Rotella's oil costs around $15 to $20 a gallon. Kubota's cost around $40 a gallon.
All recommendations will be appreciated.
Holleyman
Kubota B6001, Caterpillar 252B, AM General M813A1, Ford 8N, Komatsu PC30
Sep 25, 2013
70
80 acres in Athabasca AB
Generally if you are going to start at cold temperatures and extended oil changes then synthetic is a good choice, if not a good quality 15W-40 and change a little more often.
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
In your location you have little to gain with using synthetic. Good flow at cold temps and extended oil drains are the only real advantages to synthetics.
Three points I have learned from oil experts ( development engineers not salesmen) Use the recommended viscosity, classification, and only oil with the SAE/API starburst and donut. Everything else is trash.
Fordtech86
L3200
Aug 7, 2018
4,871
5,724
Pineville,LA
Where did you price kubota oil at $40 a gallon? First time I changed mine I went to the Kubota Dealer and got 6 qts of kubota oil and filter for about $45. I still go to the dealer to get the filter but now run rotella t5
2,215
If someone says oils are oils..........well .....walk away!;)
It is a discussion that comes up here more than .....well, I think it tops the cake!:p
Nothing wrong with any of them that you pick - make sure it is for diesel not gasoline - however, not that a gasoline oil would be bad, it does NOT have the things needed for diesels engines.
Synthetic oils are a "better" construction of oil, I use the word construction because the molecules are designed and "built" more uniform and consistent thus allowing those molecules to get into tighter places and last longer than a conventional oil.
Many don't feel that synthetics are worth the price - they do not see nor wish to see or understand the "workings" of synthetic oils. And the arguments is "why pay more for something that does not help the engine?" People have been pumping 30 weight oil in machines for 50 years and feel that it worked then, it will work now! I understand their argument, but do not agree with it!;)
Today's oils are much like today's medicine - very sophisticated.
Brand specific is only that - a specific of name and mix. All oils have to pass certain ratings to get their seal or stamp approval. Some go beyond their ratings too.
Most like to go to wally world - get a gallon of Shell Rotella 15w-40 or 5w-40. It is synthetic and fairly inexpensive when you look at the large - long range picture. Mobile 1 makes and good oil and Amsoil makes and excellent oil too.
You get what you wish and can afford - but before you do, stop and read info on the ol net about oil vs oil and conventional oils vs synthetics and make up your own mind. I'll go out on a limb and say conventional oils will be a thing of the past in the next 20 years......they will develop a newer "synthetic" oil that will be better.....and longer lasting and yup - more expensive! :eek:;)
2,872
Like the man says pick whatever color jug you like and as long as it says diesel your good to go :D
oldudbob
NC
Thanks for all the input. Amazon's price for a gallon is $44 including freight. However, I will be buying my oil from Walmart. I will probably buy Rotella T6 15W40 synthetic oil.
2,872
Its funny last time I changed everything my dealer gave me the same price as Messicks total was the same even with sales tax
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
425
23
Atascadero
Good oil! It gives good cold starting because it starts out thinner than a conventional 15/40.
mattwithcats
774
65
Any oil that’s marked “CJ4” or “CK4” will work.
“C” is for compression, diesel oil.
As a plus, look for MB 229.51, which is Mercedes diesel rating...
I would use Rotella T6 5W-40, easier starting when cold...
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Ya got me on that one my young friend, I aint got a clue what you mean :confused:
Sorry about that; The starburst is the API certification and the donut is the SAE cert for viscosity and classification.
Having these means every quart/gallon will be the same. The oil base stocks and additive package are the same. If any thing changes then the oil must be re-certified. In theory a non certified brand could have every quart on the shelf different. Probably unlikely, but likely will change once or twice over a year. Not for me.
2,872
OK I was thinking something about Starbucks and a Croissant :D
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
I can't find Rotella T6 15w40. 15w40 T5 but when I search T6 can only find 5W40.
