Engine locked up
opeth
kubota l47 and l3800
Nov 17, 2024
ontario canada
Need help. I rolled over l47 kubota. Now back in upright position engine is locked up with engine oil. I suspect oil found its way to intake manifold. Is there a decompression valve or what is the best way to fix it. Would manual spinning of the crankshaft help?. Any advice appreciated
Elliott in GA
Mar 10, 2021
829
837
North Georgia
Removing the Glo Plugs followed by manual spinning is supposed to be the easiest method.
7,152
Do not try to start the engine until you open up each cylinder by either removing the glow plugs or injectors to clear all liquids. If you don't get all the liquid out of the top of the cylinders and turn the engine over you will likely bend the rods and loose compression.
7,089
First, certainly hope no one was hurt…..
I have to ask - - how do you know the engine is locked up?
Did you try to start it? Did it fire if you tried to start it?
Seems like there’s been several occasions with tractors on their side in the last couple weeks.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
I STRONGLY agree with turning the engine over by hand and NOT the starter, with either the glow plugs out or the injectors removed. Once you know the engine is free turning, then you could use the starter.
When you look at old WWII Airforce pictures or film footage, you see ground crews hand turning the props on radial engines for a couple of revolutions to make sure that the bottom cylinders weren't hydro-locked.
Keep us posted.
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
241
280
CT
Yep pull glow plugs than spin over a couple revolutions by hand. After you get a couple revolutions you can spin it over with starter. Its gonna smoke like a sob when you first do start. Don’t be alarmed.
good luck
9,691
Pull the glow plugs, turn engine over by hand, then after several revolutions, turn the engine over with the starter.
Check the air cleaner.
5,506
2,213
exactly why I think that the way Kubota designed the intake and crankcase vent hose was not a great idea. Allows oil to run right into the intake. Engine can run on it's own oil, creating a possibility for runaway-and I have seen it happen.
remove glow plugs and battery. Once the glow plugs are out, grab the fan and turn the engine over by hand. It'll take a number of turns to get the oil out, so be plenty patient. Hopefully nothing is hurt.
PaulL
2,650
1,635
NZ
I always feel like these threads almost give enough information, but not quite enough.
I think my summary of what others have said is:
1. Rollover can lead to liquid in the cylinders. Liquid doesn't compress, so if there is more liquid in there than fits in the combustion space, if you turn it over it has to bend something. So never turn it over by starter when there's fluid in the cylinders that has nowhere to go
2. To solve that you need to give the fluid somewhere to go
3. Take out the glow plugs - this gives somewhere the fluid can escape to on the compression stroke
4. Turn the engine over by hand, because the starter will turn it too aggressively, the fluid may not escape out the glow plug holes fast enough without breaking something
5. Once you've turned it by hand, it's not clear to me if you put the glow plugs back in and crank with the starter, or whether you turn it with the starter for a bit with the glow plugs out, to clear any residual?
6. Then you put the glow plugs back in, and try starting it with the starter
7. It's probably got oil and crud all through it, so it'll smoke for a bit until that all burns off
Is that basically it?
9,691
You leave the glow plugs out and crank it with the starter.
This blows out any residual oil and it also uses the injected diesel to help wash out the cylinder.
PaulL
2,650
1,635
NZ
Excellent. When do you put the glow plugs back in? Give it 30 seconds, call it done? Or when nothing more is coming out? Or when you feel lucky?
9,691
Combination of nothing but clean fuel vapor coming out, and feeling lucky. ;)
