ECU Fuse Blows
OrangeOne
Mar 23, 2024
Estes Park CO
Howdy,
I just found this site and thought I would see if anyone else has had this problem. I purchased a new LX3310HSDC in November. It has a two year warranty so I should be covered. I am a mechanic and can generally fix anything but do not plan on diving into this unless I have to. I purchased the LX2980 snow blower with this tractor along with various other fun implements. My primary use of the tractor is snow removal from my 3 acre mountain property. Last week we got 48+ inches of snow and at the 36 inch accumulation point I went out and began clearing the snow. After about 3 hours of perfect performance the tractor suddenly died. I discovered that the KEY fuse had blown so I replaced it and the tractor worked for about 30 more minutes and died again but this time I had information on the dash display. I checked fuses and found that the ECU fuse had blown. I replaced it and again got about 20-30 minutes of good use before it blew the same fuse. Now it blows almost immediately and I have inspected all wiring bundles from the ECU to everything with no issues found. Has anyone heard of any similar issues in late model Kubota's?
2,922
Somehow you are pulling too many sustained amps. IF you have checked the wiring - there must be a dead short somewhere..
First - when your tractor is running - what is the voltage at the battery? I would hope it would be 14 ish.
SO - if the tractor is not running - disconnect the leads to the battery - trace the ground strap to the frame/engine - remove that too. Clean them bright and make em tight.
The ECU is a grounded too? Has it got wet somehow?
9,832
Send it to the dealer, way too many variables!
OrangeOne
Mar 23, 2024
Estes Park CO
The ECU has not been compromised and everything looks good. I did have a hydraulic leak from a fitting that the selling dealer did not properly tighten. I ended up filling the system (with Kubota fluid) over full...there is a fine line between full and overfull on these small tractors! I doubt this could be the problem. Today I was able to the tractor run for 30 minutes at idle, I raised and lowered the hydraulics and operated every electrical device with no issues. I yanked and pulled on all wire harnesses to see if I could get the engine to die and it did not. As soon as I began moving the tractor, it popped the fuse. BTW, the fuse is a 10 amp and I installed a 20 amp fuse just to see what happened...it also popped immediately as soon as I tried to move the tractor.
I guess I will be shoveling a lot of snow by hand tomorrow:(
whitetiger
Nov 20, 2011
3,338
1,758
Kansas City, KS
Unplug the wire harness from the Hydrostat pedal safety switch, put a jumper wire in the harness connector and you will probably not blow any more fuses. It is not uncommon for the safety switch to fail and short to ground when operating the hydro.
9,832
Sounds like and issue with the HST switch.
EDIT: YEA what @whitetiger said! 😁 ;)
Vince1230
Bx2370
May 13, 2022
158
77
Honey Grove,Pa
I would be careful using larger fuse. It alloiwed to draw mire amps more damage coukd result. Not good if wires start to melt.
