You only have to replace damaged part. Turn off the fuel, clean and replace the screen and The inside of the separator. I use carb/choke spray. If you turn the fuel switch back on while holding the plastic cup under the flow, that's an easy way to refill the cup. Screw it back together and you are done. One thing to remember is the sooner or later, you will likely have to replace that separator. The ones they send from the factory have a way of vibrating the pressed in fitting loose and the only permanent fixe is a replacement. I have had to replace 6 so far. If your machine starts to run erratically as though it's sucking air, check where the fittings for the fuel lines go into the body of the separator. If you can move them by hand, it's bad. JB Weld will seal it for a while.
