B Boldy New member Equipment Kubota L1500 Mar 16, 2020 6 0 0 Mortlake Apr 12, 2020 #1 can anyone tell me if the Hydraulic filter is also the drain plug for the Hydraulic and diff oil A Happy Easter to you all
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,713 5,128 113 Sandpoint, ID Apr 12, 2020 #2 Boldy said: can anyone tell me if the Hydraulic filter is also the drain plug for the Hydraulic and diff oil A Happy Easter to you all Click to expand... No, there is 3 of 4 drain plugs on the bottom of the cases.
B Boldy New member Equipment Kubota L1500 Mar 16, 2020 6 0 0 Mortlake Apr 13, 2020 #3 Thanks, I found 1 big plug, just a little oil comes out, and I cleaned the filter and put new oil in, it worked perfect again.
