Differential lock pedal modifications
TD Tractor
L4701, LA765 FEL, 60" Grapple, 84" Snow Blade, 60" bush hog, Ford 871,703 loader
Dec 1, 2016
23
Partlow, Va
Morning all, has anyone done a modification on the rear differential lock pedal. I got a problem with my left foot when I exsert downward pressure on my heal, it just doesn't work anymore. It's been that way for long time. I'm looking to modify the lock pedal by welding a flat pice of plate steel and extending it out a couple of inches. Any help is much appreciated!
2,744
TD,
check your linkage first - does it not engage? OR simply not rise back up?
I take it you are positive that it is not engaging? Simple test - turn front end a bit and engage - if it works, you will be pushed forward and not into the turn.
Last thing to look for, it sounds like the lock pin is sheared, which is not going to be fun to fix!
Welding a pedal onto it will allow you to hit it easier - but most people have to "find" it rather than slap the heel onto it - if you follow what I mean. The idea of the dif-lock is to want to stop movement and "find" the lock lever. It would be too easy to hit otherwise.
I would find a way to make it work be the mods!:)
TD Tractor
Dec 1, 2016
23
Partlow, Va
TD,
Thanks 85Hokie, the diff lock is working. The factory pedal just doesn't I've give my foot enough leverage to engage it.
2,744
I gotcha!
Can you "bolt" something to it as opposed to welding? Flat plate with circular loop that could have a jamb bolt attached? That way it could removed if need be:)
bearbait
Dec 9, 2011
4,104
879
New Glasgow Canada
I'm having the same trouble as you TD, I'm wondering if the spring or whatever it is may be too heavy making it difficult to push down and hold down. If it is a spring maybe swapping it out for a lighter one would help.
bearbait
Dec 9, 2011
4,104
879
New Glasgow Canada
billrigsby
Mar 17, 2015
1,034
213
Florissant CO USA 8213'
www.facebook.com
I gotcha!
Like this.................
http://www.boltonhooks.com/jd1series.html
This is for one of those "Waste Management"
colored tractors, but may work,
and it does not need to be painted :D
Kennyd4110
Vendor Member
Sep 7, 2013
1,333
632
Westminster, MD
www.boltonhooks.com
We are working on a more universal clamp on design that should fit a variety of models and colors.
At least they don't turn pink in the sun :p :D
Brazos
L2501DT
Jul 12, 2016
122
I would be very interested in a product like that. My different lock is about useless as my heel slips off of it (like others said the spring is really heavy). If nothing else I may put some skate board tape on it.
lddykstra
L3940HSTC
Feb 5, 2014
23
Rock Valley, Iowa
I changed the Spring on the linkage out to a less powerful spring. It has worked great. Now I dont have to stand on the pedal which shuts the tractor off by the way. Now I just need to rest my foot on the pedal to engage it and the spring still disengaged it like it should with no adverse effect.
I got the spring at my local farm store.
TD Tractor
Dec 1, 2016
23
Partlow, Va
Thanks all for your help! I looked at the spring today. I think that changing the spring is the first thing I am going try.
Thanks again!
