Diesel Transfer Tank Build
Trimley
BX23S-1 with additions
Jul 25, 2023
725
499
PNW-WA
Prior to buying my BX23s in August this year, I started watching Craigslist, Local For Sale and FB Marketplace for a Diesel Transfer Tank. Something reasonable. Last month I found a 50 gallon Aluminum Hydraulic Tank, which was just what I was wanting for size. I picked it up for $50.
I found a nice (older) Hand Pump for $50. It needed a hose (new 3/4"×12ft installed) and filter (in route).
I bought the necessary fittings and plugs for the bottom of the tank, and threaded bung for the top, which was Tig Welded on at the filler neck. I picked that up from the local weld shop today, along with two 1/16"×2"×70" Stainless strips which will be used as straps to hold the tank to a wood cradle once made.
I had to remove the down tube from the pump and shorten that as well. Disassembly was interesting to do to avoid damage.
I also added an anti-kink coupler into the hose. I'm gaining headway.
Reactions: 10 users
Smokeydog
Jun 2, 2020
484
466
knoxville, Tennessee
Nice tank!
You going to take it to fill or have have it filled on site?
Is there a bottom drain?
Vent? A tank vacuum/pressure valve will help keep the condensation out.
leveraddict
Apr 1, 2019
889
553
NEPA
Wow! I hope thats not just for the BX? Over kill unless you have a few diesels? A BX sips fuel. Unless your planning to put 500 hrs per year on your tractor, start planning on treating that tank before stuff starts growing in it and it will! I would rather pick up fresh fuel 5 gallons at a time! BIG tractor different story! 50 gallons should get you close to 600 hrs on the BX and they do not tolerate old fuel with stuff growing in it and you dont want to have to pull the tank to clean it.
1,386
Nice find!
That should "fill her up" quick!
Trimley
Jul 25, 2023
725
499
PNW-WA
Nice tank!
I'll take it to fill. I plan a wood cradle, then the tank banded to it. I also plan to have lifting eyes (one each end of cradle - 4 total) to lift with FEL.
Bottom Drain, Yes. Not a water bleed off.
Vent, Yes.
Trimley
Jul 25, 2023
725
499
PNW-WA
The plan is strictly for the BX, which the tank will be stored inside my shop. I built the tank to eliminate the need to fill/lift the cans, due to a handicap of the left hand, so I guess if I need to add additives to prevent growth, so be it. I live on the Washington Coast. Temps in the winter below freezing (upper teens) are short term. A couple weeks on the average. Summer Temps get to 95° +/-, July-August. Average in the shop, 70° or less.
I've researched additives based on Washington's coastal region. Finding regional info doesn't exhist. Standards, storage longevity and treatment recommendations are a plenty. The same said for what's the best choice for additives. That in itself is beyond confusing, so I'm open to suggestions.
4,001
SOLTRON (NOT startron) to treat for bio growth, it designed for costal areas with high moisture.
Stanadyne to stabilize.
NAPA has both
leveraddict
Apr 1, 2019
889
553
NEPA
Summer temps to 95 worse inside the garage? I dont know how much you will use your BX23S but 50 gallons of fuel could last a few years! I put the 5 gallon jug on the floor and use a cheap D battery pump to fill. Its quick easy and fuel is always fresh. I have never stored fuel for years. Maybe others will chime in on longevity? I have my BX23S 6 years now with almost 700 hrs and I probably use 15 gallons a year. My hours are mostly dirt work FEL and BH with mowing (not much) and little snow removal. Good luck I hope it works for you.
Countrylife
L235, RTV 900
May 12, 2022
22
East Texas
I assume that you plan to lift it into the bed of your truck to haul it to the gas station so it won't be permanently mounted. Have you checked to see if the station will allow you to fill it? Some stations require tanks that are not permanently mounted to be placed on the ground before filling and at 350# just for the fuel, you're not likely to be able to do that.
4,001
I'm pretty sure that only applies to plastic containers being filled with gasoline.
This is due to it's being explosive when it's got the potential for there to be a static spark.
A 50 gallon aluminum tank is in itself a semi permanent setup, and it's being filled with diesel which is not ignited with a spark.
Trimley
Jul 25, 2023
725
499
PNW-WA
Temps inside my shop remain considerably cooler than outside Temps due to the monolithic concrete pour. I have tendency to keep the doors closed most of the time to keep it cooler, and so mice don't get in.
50 gallons is a lot, but I'm going to try it. When I made the transition to diesel from a gas guzzling John Deere, I knew there was more involved. I'm OK with that. I'm mechanically inclined, have the Service Manuals, and am prepared to see how it plays out. At this time two years from now, the tank could be trouble free or sold. Let's find out.
Trimley
Jul 25, 2023
725
499
PNW-WA
Yes and yes, into a boxed sided trailer. The tank will be on skids and lifted with the tractor. There are several filling areas here where I can fill it.
Trimley
Jul 25, 2023
725
499
PNW-WA
NAPA has both
NAPA never had them on the shelf. They will both be there when I stop in today. Gotta love them, their quick. 👍
4,001
One thing that helps is a barometric vent, it controls air in and out.
Trimley
Jul 25, 2023
725
499
PNW-WA
For the time being all I have is a 3/8" nipple and a cap held on with stainless tie-wire. So the cap doesn't dissappear.
Today I plotted two 4"×6"×28s with their radius and made the cradle stands and temp fastened the 1/16"×2" straps into place. Now I need to find four round rod t-bolts to go through a bend (hole) in the strap while at the same time go through the 6" height of the cradle to suck the tank down so it stays there. After that I plan two pieces of 1/4"×2" flatbar from leg to leg with a hole on each end and a slight upward bend for lifting eyes. The flatbar will also hold the span distance set in the cradle.
Sometimes living out in the sticks is a headache when I need things....sigh.
