coachgeo
Bought an L225 and belly mower that runs real nice. thought was to put its D1101 into the L235DT I have along with belly mower and sell off parts ending up a tad better dollar wise.
Now I see though:
. the Hydraulic pump is different, Can a swap the D1102 unit onto the IP on the 1101?
. Water pump is different. Will/should I swap pumps and cover (aka does one push coolant better if swapable?)
. Oil pan different since mine is DT but that was a known going in and previously had been told that was swapable.
. Did I just loose ability to add a FEL? Looked like L225's block (D1101) didn't have the cast in location to bolt up FEL. It mounts onto the L235 block (D1102) right; or does the L235 FEL actually bolt onto part of the tranny and Im remembering wrong? (neither tractor handy to run out to look at)
Woods finish belly mower.
. Assume I need longer belt from rear PTO to Woods mower since the wheel base is different?
If I read it write the spech page labels RIM as TIRE and Tread as Rubber/Tire. Correct?
http://www.tractordata.com/farm-tractors/001/2/8/1280-kubota-l225.html
http://www.tractordata.com/farm-tractors/001/2/8/1281-kubota-l235.html
even with that confusion. the L225 is Turf all the way around. Thought that rears on 25 would work on 35 while might needing another set of turf front rims for the 35. Now Im not sure.
Advice?
Now I see though:
Advice?
