Damn. Antifreeze in the intake manifold and engine won't crank.
Sgtwal
26
Terre Haute, IN.
I think my B6100E and D750 are toast.
I bought this as a basket case and after a fist full of barked knuckles it ran like a sewing machine and worked like a champ.
Then after it sat a while it won't crank over. It comes to a stop when cranking like it has hit something solid inside.
When I pulled the intake off to start to pull the head to look for FOD I found it had antifreeze in the manifold.
Maybe I'm wrong but that sounds like a cracked head.
At over a grand for a new head assembly I may have some used parts for sale soon.
bucktail
Jun 13, 2016
1,234
181
MN
Have you made sure it's not just the head gasket?
CountryBumkin
Sep 27, 2015
568
Central FL
Get a radiator pressure tester - then pump it up to about 15 psi and see if you can spot the leak. If pressure drops and you don't have an external leak, that will be a good start to finding out exactly what went wrong.
Or you can just disassemble, check everything as best you can, replace the gaskets (have head tested for cracks), hope the block is okay, and reassemble.
Good luck.
4,415
Sarg, it may very well just be a head gasket. Gotta think positive! Like CountryBumkin said, pressurize the cooling system to see if you can determine where the leak is.
When you remove the head look for signs of a gasket leak. Take the head to a machine shop and have them magnaflux it. You'll then know for sure of it's health. THEN decide on what direction you want to take.
5,181
Head gasket is $45
New head is $450
Used head is less.
Sgtwal
26
Terre Haute, IN.
Well finally had time to pull the head. All 3 cylinders had water in them.
Checked piston travel and everything look OK. Am looking for a local shop to have the head checked.
5,181
It's very common when one cylinder has water other can too because of the way the intake and exhaust is set up.
If the head is cracked you can usually see it, it will crack between the intake and the exhaust or pre-chamber or glow plug.
Sgtwal
26
Terre Haute, IN.
Finally had time to pull head and have it checked. The found 2 cracks in 2 cylinders running from the intake valve to the glow plug cover.
Does anyone have a recommendation for a source for a good used head, or a super deal on a new one?
Sgtwal
26
Terre Haute, IN.
I found a brand new naked head on the internet for $450.
In my mind a new head for less would be nice, and a good used head with valves already seated for less than half that for an example.
However, we can't always what we wish for can we?
