D1005 Powered Geo Metro, Governor Help, please
planejob
D1005 powered Geo Metro
Mar 28, 2016
Wylie (Dallas), Texas, USA
Hello folks,
I've recently tucked a Kubota D1005 3 cylinder into a Geo Metro. Successfully.
Before you call BS, here's the video from last weekend: https://www.youtube.com/watch?v=_5cTk5PIzss
The issue I'm having is this: the engine was originally affixed to a generator and does not like to rev up. I'd like to turn it up to 3200 to 3600rpm.
I *do* want to keep the governor - there's no need to take it out and blow the thing up.
So my question is this, can I lighten the fly weights to increase the governor RPM? If I'm governed at X and I lighten the fly weights by half can I then rev to 2X? I think the engine is currently governed at somewhere near 2000 (the lever was set to 1800 for the generator). I have an optical tachometer from Amazon headed my way to confirm all of this.
If you are interested the struggles/build are chronicled <here>.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Hello folks, I've recently tucked a Kubota D1005 3 cylinder into a Geo Metro. Successfully. .....So my question is this, ....
LOVE IT. I'm putting a D722 in a Motorcycle.
While this is a GREAT site here at OTT...... There is not too many of folk in here who dive into modifying these little diesels. With that in mind; I'd Suggest you go to suckindiesel.com/thingy. Though it is a diesel motorcycle discussion board...... we do have to go thru the same issues of modifying IP's, Governors etc.
I seem to recall a thread there just on same topic (different motor, same issue)
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
First.... I love anything diesel. Great job !! FYI... I have one of the first Ram EcoDiesel's to roll off the line, and love it. I can break 30 mpg on any long trip.
Anyway... I know you were asking about mod'ing the weights... but they used the 1000cc engine in some of the tractors at +3000 RPM. I would think you could just order the weight set from that pump. (don't know, just thinking out loud)
@Coachgeo : Do you have a link to your project bike?? I would love to see it too.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
....@Coachgeo : Do you have a link to your project bike?? I would love to see it too.
Long soap opera thread and notes on her getting built are at site I sent this fellow to in second post of this thread.
She's not done yet.
aeronutt
Z725 Mower, MX5200 w/FEL, Stihl 660, assorted others...
Jan 7, 2016
120
Omaha NE
Lighter weights or stronger springs will both increase top speed. Might try tying a few coils of the spring together with fine wire just to experiment with what difference it makes. That's an easy way to adjust the spring tension without making permanent changes. Filing down the weights is kinda permanent, so do a little bit at a time to make sure you don't overdo it.
Love the idea. Best wishes for a successful outcome!
planejob
Mar 28, 2016
Can you provide any guidance as to which spring controls the fly weights?
aeronutt
Jan 7, 2016
120
Omaha NE
I have never worked on that particular engine so I can only offer general concept help, not specific answers. Most fly weight type governors work on the same principle though so it shouldn't be too hard to figure out.
If you grab the fly weights and pull them out manually, the spring that resists that movement should be pretty easy to identify.
9,777
You don't need to change anything, that model has an adjustable speed limit.
I'll send you a link to download a WSM (service manual) for a b2110, that has the same motor as your working with, look at page 1-S26 for the adjustment bolt.
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
How can you not love this.
If it does not work out you can always mount a snow blower or blade on the front and sell it in Michigan.
7,213
What do you mean, if it doesn't work out... He's already posted video of driving it around the block!
When you take an idea no one else had done and get it to the stage Planejob has, it's pretty well worked out. He's just fine tuning now.
No backing up to a snow blower, at least not because of failure to original project.:D
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
D2Cat I was just making a joke. The same type I heard about the tractor engines in our old British sports cars. I am in full agreement on the accomplishments of this project.
I can't wait to hear the fuel consumption numbers.
planejob
Mar 28, 2016
Hey, I am sticking around a while, I've got to figure this thing out.
I have good news and bad news:
First, the car runs down the road just fine. I got a transit permit for it and took it up to get an exhaust put on. The guys at the "Wylie Used Tire and Muffler" thought this was a sight to behold. I got the exhaust.
The car maxed out at about 42 MPH. It takes off in 1st too easily - it's a granny gear that won't be of much use as is*. It takes off in second fine. THird and fourth are easy enough, but fifth... non existent. pulled the 'top hat' on the tranny and both the fifth gear drive and driven gears were toast. Eaten up so bad I could spin them by hand in opposite directions simultaneously.
So I tried to warranty the junkyard box - they said sure - you can have any transmission in the yard... too bad they didn't have a single manual Geo tranny in any of their three yards. That took a whole Saturday. The decision was made to rebuild.
I don't know anything about rebuilding Geo Transmissions... but I'm about to learn!
So you saw the asterisk earlier... in the process of deciding to rebuild I was offered a new Final Drive for the transmission. I'm going from a 4.1 final to a 3.52 final. (16%):D
Without even changing my guvna I'll be able to touch 60mph! I'd like to turn it up to 3000, that would be good for 75 (unless I become drag limited). 3600 would allow the gearing to carry it to 91mph, but I'm not sure how steep the hill would have to be to overcome the drag:confused:
I got the WSM from North Idaho Wolfman, so a big THANKS for that. I'll study on it over the next few days.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Hey Planejob, congrats on your success so far! I give you a lot of kudos for taking on such a serious fabrication and engineering effort.
When I read your post the first time, it looked like you tried starting in first, then starting in second, then starting in third and so on. It seemed like starting in 5th is what blew the tranny....then I read back and I suspect you were just saying you can start in first or second, third and 4th shift ok, and then 5th didn't exist when you shifted into it.
Good luck with the rebuild. I wonder what issues you might have with the torque on that D1005 destroying the trans? Be careful not to start in too high of a gear...
Getting that final drive lower will be a HUGE help. Diesels always like a lower final compared to a gasser.
I would say starting with a gov setting around 2800 would be a good start (lots of the Kubota's are rated at that rpm) and see if it serves your needs. Since you're not trying to make a rocket, just a MPG beast, 75 would likely be as fast as you'd want to go. 3600 is pushing it in a Kubota (or any diesel rated for 2500-3000rpm) IMO.
There are a few guys who slipped turbos into their tractors...that's your next mod! More hp and likely a little better MPG.
7,213
It's too early for me to think clearly. Isn't he going to a higher final drive? " I'm going from a 4.1 final to a 3.52 final. (16%)"
Billdog350
Jan 6, 2014
468
11
East Hampton, CT
Going TO a 3.52 will LOWER his RPM and give him higher top speed before the governor kicks in....
think of it this way, the current one needs the engine/transmission to turn 4.1 times for every revolution of the wheel, it WILL be only 3.52 times to get the wheel to turn once.
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
And that, my friends, is expressed as HIGHER gearing. :)
