This is how you do it....
If the air vent valve doesnt work (which is located on the return fuel line from the injectors) then do this....
What you will need:
17mm box wrench
Charge/Jumper box that plugs into a wall
Eye Protection
FULL fuel tank
1. With the tractor off, fuel tank full, loosen the rear injector nut (17mm, injector closest to gas tank) until you are able to shake the injector line a little ensuring it is loose and will leak fuel out (which is the intent). No need to loosen all the way, just a bit until you can wiggle the injector line.
2. Hook up a charge box to the battery - set it to Jump (either 40A or 200A).
3. Crank the tractor while watching the rear injector... keep cranking with 15 second intervals until you see fuel SHOOT out of the top of the rear injector nut (not "seep out" but "SHOOT/squirt" out) with a good amount of pressure. If the tractor begins to run, just shut it off... and keep cranking. If you still see air bubbles coming out with fuel, then keep going. Give starter a break after 15 second intervals.
4. Tighten rear injector nut.
5. Do the same for the middle injector... only this time... if it starts to run... let it run at idle RPM. The middle cylinder will be missing but that is ok at idle RPM.
6. After fuel is squirting out the middle injector with a good amount of pressure, turn OFF tractor and tighten middle injector nut.
7. Go ahead and loosen front injector nut until you can shake fuel line loose. Start tractor. Let run at idle RPM until you see the fuel shooting out from front injector. All air bubbles should be gone by now. A kubota mechanic told me to tighten the front injector back up with the engine running, but I would recommend on here that you shut the tractor off... and then tighten the front injector back up.
8. After the front injector is tightened back up, you should be able to start the tractor and it should run idle smoothly and no fuel should be leaking anywhere of course. Let it run
ONLY IDLE for a while. And you can open the air vent valve to let any remaining air escape the lines. Let it run like this at idle for 10 minutes.
9. CLOSE the air vent valve. Then rev the RPMs up to the 540 mark (2200 rpm or so) and run there for 2 minutes. If there is any air in the lines left, the tractor will begin to stall at high RPMs like this... just let the RPMs drop back to idle and run with the air vent valve open for several more minutes.
10. After this is done, CLOSE the air vent valve back up. All done.
