This isnt up there with Paul's fantastic stuff, but I did not want to take my Piranha Tooth Bar off just to push some snow, nor did I want to grind the teeth on that Piranha Tooth Bar against the asphalt and concrete!
So what I did was take a plate of steel, weld 4 large bolts to it, grade 5, then made plate steel washers to squeeze around the tooth bar. Now I have a scraper edge that I can beet the hell out of and not really care about. Loosen the four nuts and it slides right off. The bolts will not allow it to slide back any further than it is right now.
I will see if it works......if/when this white stuff starts to fall!!!!
