Cutting edge for Kubota B2601 with 54 inch bucket
Petey Kubota
B2601 Kubota loader back hoe
Milford PA
Any one know where to get a bolt on cutting edge for the bucket on my Kubota b2601 with a bucket model number b2324 with seven holes that are ~7 3/8 inch spaced. and total bucket is 54 inches
je1279
Dec 6, 2020
828
585
Upstate NY
I don't see anything through Kubota but you could could get an aftermarket tooth bar for your bucket.
je1279
Dec 6, 2020
828
585
Upstate NY
I'm not familiar with straight cutting edges but I know a lot of folks rave about the Everything Attachments tooth bars also.
je1279
Dec 6, 2020
828
585
Upstate NY
Here is the parts diagram I found for that bucket. Couldn't find any reference to a cutting edge.
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
138
46
newark valley new york
The cutting edge for the 54 inch B2371 quick attach bucket on the LA435 is accessory B2373. Not sure if that would fit your bucket?
5,708
weird. I found the bucket with the holes for the cutting edge, but not the cutting edge by itself.
3,238
Your question is pretty specific regarding looking for a bolt on cutting edge.
But have you considered a tooth bar? Perhaps you do not want the teeth, and if so then a tooth bar would not be of interest. I have a tooth bar that I would would never want to be without. It is on the bucket most of the year, but I take it off in winter when dealing with snow.
Do not know your needs. Just suggesting a tooth bar as an option if you are not necessarily looking for a straight cutting edge, but rather something to protect the bucked edge from wear.
Frankb
Kubota B2601, FEL, Backhoe, Belly Mower, Grapple, Rear Scrape Blade
Apr 3, 2011
239
66
Person County NC
I have the bolt on cutting edge and bought it from local dealer. I had to order, but it came rather quickly and included bolts ad nuts. Very pleased with it.
5,773
While you're waiting for delivery of a 'real' one, Get a 54" length of 2"- 2.5" barstock, 3/8" thick, drill the 7, 5/8" holes,bolt onto the bucket. While not 'hard' steel, at least you'd be 'up and running'..moving material.
Kinda odd that K doesn't offer one though, they do for the BX23S SSQA bucket
ultra97rider
B2401
Jul 3, 2021
19
12
Blountville, Tn
Call Messicks. A very knowledgeable and dependable staff.
Actually called them yesterday on the exact question. they were not helpful or knowledgeable. If the OP has the B2371 54" quick connect bucket you want part B2373 comes as a kit for $177.00 plus shipping from Messicks. Coleman's wants $199.00 plus shipping. or you can get the Blade and hardware separately for $122.00 plus shipping. The kit is painted, which will cost $55.00 extra. The Paint will most likely flake off the first time you use it.
Messicks Parts does not sell the Kit, you need the purchase it from the tractor sales Department as an accessory. Took me 3 calls to Messicks to get that Info. One of the parts guys was very rude.
1greenthumb
9
Gloucester, VA
Kubota does make one, I ordered mine from my dealer. Invoice states B2373 as part # and it was $175.00. This was through a local Land & Coates dealer.
Frankb
Apr 3, 2011
239
66
Person County NC
As I stated in other post above, my cutting edge came from my local Kubota dealer. Just under $200, and included the bolts and nuts for the install. Fit perfect, and I use it all the time and it still shows no wear at all. Great protection for the bucket edge. The bucket came with the holes drilled so they had to have the bar option to go with it or I don't think they would have put the holes in the bucket to begin with. Noticing the holes in the bucket is what got me to inquire about the cutting edge to begin with or I might not have even noticed the bucket not having any protection until it was too late!
Hope this helps.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
There is an edge available for the pin-on bucket. I don't know if it would fit.
