Cultivator question
lakehouse_dreaming
L3901HST, LA525 FEL, RGA1258 tiller, RCR1860 rotary cutter
Nov 2, 2021
59
125
This is my grandads old cultivator that I have, however everything I can find now has springs on it like a spring tooth plow. Is this one just missing the springs or did they used to make them as a rigid plow?
1EE5C293-2B5F-411E-82A3-AE9F6AA9FA66.jpeg 0DAB016E-38A2-46F2-8536-A4BFEC70C801.jpeg
bird dogger
Vendor Member
Feb 24, 2019
1,790
1,766
North Dakota
No parts missing there. Pretty unique. I like how you can set the tooth angle. If memory serves correctly that would more likely be called a chisel plow........maybe?
Edit: chisel plow...... a soil tillage device pulled by a tractor or animal, used to break up and stir soil a foot or more beneath the surface without turning it.
I see some old IH chisel plows that look very similar. Yours could be a real early version IH unit.
6,285
as BD says ... 'NICE' !!!!
You should set it on 3or 4 high concrete blocks( enough to keep 'points' out of the ground ).
That way YOUR grankids can still be using it !
I'd also remove the chain and try to prop on an angle so water won't sit on he angl iron frame pieces.
I used a similar one 20+ years ago, to turn 1/2 ac of grass(sod) into a veggie garden. Took a zillion passes but it's all I had back then.
3,165
1,286
Is there any markings on it to identify the brand? A lot of times on older equipment the cast their insignia or logo into some of the parts. Neat looking piece.
Captain13
Feb 27, 2019
523
171
Kathleen, GA
They used to make them as a rigid plow. The springs came along to lessen the chance of snagging a big rock or root and bending the frame. I have an old Massey cultivator and it had rigid mounted points. The rear frame mounting rail was curved up due to catching hard stuff in the ground. I disassembled the thing, used a press to straighten it and have been using it for over 20 years now. I got it for free when it didn’t sell at an estate sale. I switched some of the chisel points to sweeps for maintaining my big garden. keeps the row centers clean and pulls dirt up to the plants.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,289
183
Coyote Flats,Texas
Rowcrop cultivators such as shown in photo were designed to move relating loose soil in order to control weeds in planted crops. Therefore as Captain13 previously stated some older rowcrop cultivators had no springs
lakehouse_dreaming
Nov 2, 2021
59
125
Not that I could see. I will have a closer look in the daylight and see.
bird dogger
Vendor Member
Feb 24, 2019
1,790
1,766
North Dakota
That center knife assembly is interesting. Some sort of depth control device, maybe? I'd clean that bad boy up and put it to use again!! You'll most likely find some part numbers cast into the curved chisel holders that can help lead to identification. Which could then lead to an owner's/operating manual. That would be neat to have!!
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I watched an old Ferguson video from the 50's and they used a cultivator like that. They said the knife acts like a rudder to keep the unit from moving side to side.
bird dogger
Vendor Member
Feb 24, 2019
1,790
1,766
North Dakota
3,165
1,286
Here ya go: Ferguson Nko-21 Rigid Tine Cultivator
Ferguson Nko-21 Rigid Tine Cultivator - TractorShed.com
It looks really close. This one has some shields on it set up for protecting the row crop
David.
Edit: Here's another link to one Ferguson Implements - Yesterday's Tractors (yesterdaystractors.com)
Possibly even a copy of a manual??
Here's a free manual in PDF format for you: Ferguson N-KO-21 Assembly and Operating Instructions (ntractorclub.com)
Mystery solved! :)
Nice research.
lakehouse_dreaming
Nov 2, 2021
59
125
Captain13
Feb 27, 2019
523
171
Kathleen, GA
instead off that center knife, mine has a 12 inch flat disk that acts like a rudder to keep it straight. Make sure you never make a turn (other that slight steering adjustments) with the points in the ground, or you might bend the frame.
bird dogger
Vendor Member
Feb 24, 2019
1,790
1,766
North Dakota
Easy to see it was set up for cultivating two rows of a row crop. Betting you'd find the distance between the two rows (gaps in the cultivator shovels) is about 36" on center and it was set up to cultivate your grandad's corn crop......or tobacco maybe?
A little sandblasting and a fresh coat of Ferguson gray paint would have that looking pretty spiffy again!
From the manual, it looks like there's an infinite number of row spacings you could set that up for. Perfect for your garden use!!
