connection for working lights B2620
Ben S
B2620 FEL MMM mcconell swingtrim
Jan 17, 2015
128
Holland
found the connection for working lights B2620
hello,
can someone post a picture of the working light electrical connection on a B2620 so that i have the correct wires to hook op rops lights?
thanks.
3,091
hello,
thanks.
Ben,
I 'll bite -
Let me make sure I understand - you want to ADD some (ROPS) lights and tie them into you current wiring system?
3,091
yes. thats why i want to know were to connect. :confused:
What I would do - and did.
If you want only one switch for one circuit - then I would get a relay - A relay is a low amp cut on/off for a higher amp circuit. In other words the current does not have to go through the switch.
A relay will run you a few bucks - and with a fuse will protect all other power sources on the tractor, you will run the load end to the lights, the switched end to the switch the hot feed to the battery and the ground to the frame or battery.
Your lights will be controlled by your switch - which will cut on/off the relay.
I would have the wires run up the ROPS in some kind of wiring loom, zip tie them to the upper legs. The lights - I would get 2 or 4 LED lights and attach them where/how you see fit. All light wires run back to the load on the relay.
Let me know if you need anything else. :)
aeblank
411
Cadillac, MI
I ran LEDs, and skipped the relay. 5A switches that mount in a round hole. Easy peasy. 2000 lumens for like $20. Crazy good.
Sent from my XT1254 using Tapatalk
Ben S
Jan 17, 2015
128
Holland
got it! :D
under the right fender between the ROPS and taillight.
Two wires with a male-female plug.
wow what a light. :)
