Chain saw chain sharpeners
5,640
I should be sharpening my chains, but it is a PIA with a file and the jig. Yeah I know there are guys that can do it in their sleep. I aint one of them, and 12 bucks to sharpen a chain, (thats the cost around here, someplace Im sure its cheaper and this is what i have to deal with), well I need to figure something else out. So tell me boys and girls what are you doing to sharpen your chains?
UpNorthMI
May 12, 2020
849
568
Up North, MI
I have a large stock of chains for my numerous saws and just change out the chains several times a day, like you I was not great with a file and agree it is a PIA. I purchased a very cheap electric chain saw sharpener to see if this method is better, my intent was to eventually invest in a much more robust chain saw sharpener but I'm still using my $24 (on special) unit.
The results are very good, yes it has a plastic body and lots of plastic parts but it meets all of the requirements to sharpen saw chains quickly and with a reasonable degree of accuracy.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
I like the Husqvarna guides. Can be found at Tractor Supply or online. All of my saws are chisel 3/8 .050 or 3/8p .050. I have both guides and files. A few licks between tanks is all it needs, unless you hit something.... I had .325 on a few saws and couldn't for the life of me sharpen them with the guides, so everything got switched to 3/8's.
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
I just use the proper sized round file. For my occasional homeowner trimming of downed trees it cuts just fine.
Along this same discussion - My son worked for a tree-cutting company for many years. (Clearing under miles of powerlines and storm response) He headed up a team of guys that run many saws all day long every day for a living.
I once asked him how often do you guys sharpen their chains?
I expected him to say something like "We sharpen the chains twice a day"
I was VERY surprised when his answer was "As long as you do not touch the ground or have muddy wood, a chain stays sharp for a WEEK!!"
To be fair, these guys were using professional chains (more teeth per foot) on 4+ HP saws sharpened to chisel-point with FLAT file.... but still.... A whole week of daily cutting is impressive.
torch
Jun 10, 2016
2,885
1,130
Muskoka, Ont.
I have the Princess Auto version of the Oregon 410 type saw chain grinders. It is one of many Chinese knock-offs and like all the others, required a bit of tuning and polishing out of the box. But once it is "race prepped" it produces wicked sharp chains on par with the original factory grind, even after a loop has had an unfortunate encounter with an embedded stone or nail.
SidecarFlip
Banned
563
+1. I have one too but I prefer the Stihl, Husky, Pferd file giude for a tpuch up. Bad chipped teeth, I use the grinder.
Don't like store ground loops. They charge you a bundle and remove way too much tooth because they want you to buy more loops.
SidecarFlip
Banned
563
armylifer
Mar 26, 2013
2,329
1,085
Thurston County, WA
I just use a file with a guide. I have been using that for 40 years. I tried an Oregon Brand chain sharpener a few times but I could not get the hang of it. I have been using a file for so long it is like second nature for me.
7,007
I'll second the Stihl 2 in one. I have one for each saw (two different pitches). They are well worth it and easy to use.
Try it Skeets.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,468
657
Richmond, Virginia
I use the Demel attachment. For years I used files and clamp on jigs with not a lot of success. 'Ureka' was realizing what part of the hook needed touchng, which is the lip at the tip. I still use the Dremel but a file would work too, the Dremel also reminds me of the correct angle (and I am lazy).
I used to keep a dozen chains on hand, swapping rather than sharpening (and sharpening poorly to boot!) I also used to cut until the chain would not cut anymore. Now, I sharpen after each use or if I am cutting a lot, during the job. Still on the same chain on each of the saws I bought over the last eight years. One is getting close to worn out but it still cuts like new. I had a 'pro' do a bunch of chains once, his job was no better than mine at the time (which was not very good).
Slowly I learned to know when a chain was dulling, when the bar was worn. It is so nice to have a well maintaned saw that you can just set on a log and have it rip through.
UpNorthMI
May 12, 2020
849
568
Up North, MI
Try it Skeets.
All my saws are Stihl, I just ordered a 3/8P Stihl 2 in one sharpener and will give it a try, I've only used the old style files before. Thanks for all the input and recommendations from everyone on this.
7,007
Just an FYI to all...The stihl 2 in one can be used on any saw that has the correct pitch chain. I have one in 3/8" and one in .325"....they are both Husqvarna saws. You can get the Stihl 2 in 1 on amazon or many ACE hardware stores carry them. Well worth the $.
michigander
547
234
Northern Michigan
I cured a lot of my dull issues switching to plastic wedges a few years back.
That harbor freight electric sure looks tempting , I'm currently using dremel as like other posting local sharpening isn't worth it.
Amazon Oregon chain is $17.00 for echo timber wolf.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
I've been using the cheapo Harbor Freight electric sharpener I bought with a coupon for $19.95. I have been using it for a few years. No problems with it. I have a stock of chains for all my chain saws and when they dull up, I change them and hang the dull ones on a nail in the barn. When I get a stock of them, I set up in my nice warm wood stove basement and grind away. My neighbor spent $350.00 on a "Professional" quality sharpener and asked me to show him how to sharpen his chains and I couldn't believe it wasn't much better than my cheapo version.
7,676
I've been using one like this for 30 years. I have a fancy Oregon sharpener that cost over $200 years ago, and I haven't used it 2 hours total.
SidecarFlip
Banned
563
The Stihl and the Husky are the same (different colors).
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,210
1,826
Pittsburgh
I use the Carlton File-O-Plate. It does require you to know how to properly wield a file.
5,640
I have the same one D2, yes it works, maybe Im just gettin old
Thunder chicken
M7060
Dec 29, 2019
303
123
Northern ontario
With the saw clamped securely in a vice, a good file and some practice is as fast and almost as good as any jig. it's taken me a while to figure it out but if i can, trust me, you can too.
As soon as the file feels like it's not cutting metal, chuck it and get a new one.
A guide on the file is a good help to start. As is the depth gauge for the rakers. A good flat file is needed for them. I believe hitting those rakers every couple of sharpens is as important as a good edge on the tooth itself.
I have not tried a 2n1 Sthil file but i'd like to. it looks handy.
'Buckin' Billy' on youtube has some good sharpening videos, (as do others).
Or, make friends with guys who make a living in the woods. :)
