If you remember my thread on putting something plastic on my back blade so as not to gouge up the new concrete?
Well I decided to try the trex approach first before spending money on the stuff designed for the job, and today stopped by a new builder's supply place. Turned out they didn't carry lumber for sale, tney were into kitchens and such, but the boss remembered there was some deck boards out back and he gave me a 12 foot board, and one of the employees cut it in half with a handy chop saw. Free is good! Kindness is remembered! I'll go back.
So I set out to take off the steel edge and put on the 1 x 6 board. Undo 6 bolts take off edge, clamp board in place and mark for hole locations, drill holes, put back bolts, how hard could that be? Well other than the steel edge has square holes in it to make it easy to tighten the nuts without spinning the bolts, until they are loose, and then they are a pain, and the fact that the steel edge weighs about as much as I do, and is now balanced across two dollies, the first part was ok.
Turns out that trex is pretty hard to drill, but I managed to get 6 holes in it big enough for the threaded parts of my bolts with a paddle bit. However I can't think of a way to make a bigger square hole on the other side to fit the shoulders of the bolts that go with the blade and leave a flat round surface flush with the edge. I tried to drill a larger inset with a bigger paddle bit, but couldn't center it with hand held drill. Betting that if you want to do that you drill the bigger hole first? But my marks were on the wrong side of the board and too late now. I am now thinking that never mind countersinking the bolt heads, just go buy some other kind of bolts and leave them stick out with a washer behind the head. The bolt heads will be on the exposed plowing surface.
I thought I'd ask for advice on bolt choices and other ideas before I wasted too much time. My tools selection is pretty limited.
