Can someone explain this bracket?
igizzzmo1
47
Elmira, Or
I looked down to find this bracket bent and dangling. Tried hooking it back up with a new bolt and bent the crap out of it. I don't see its purpose?
2,838
The stick that is on the right of the tractor when at the wheel - what does it do ? 3rd function valve?
TripleR
Sep 16, 2011
1,911
SE Missouri
Need a wider shot, doesn't look familiar to me.
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
Could it be a bucket level indicator? It looks like it may have attached to the bucket.
8,249
Ok, bad guess on the first attempt. Looking at it on my tablet now. :eek: I'm thinking that it is for your load level indicator for the bucket. With out seeing the rest of the linkage, I'm not positive.
igizzzmo1
47
Elmira, Or
It did move back and forth with bucket. I don't get how a thin piece of metal can level loads. The hydraulics will override that little thing. I am new to this tractor but I have been running full speed ever since I got it.
2,838
I typed what I thought at first, it was a leg that holds the FEL up when not in use, then after looking again, realized that was not it ....noticed the control arm at the top......I too thought it was a level indicator! :D:)
6,677
" I don't get how a thin piece of metal can level loads."
It's an indicator. Not a leveler. It indicates, you level--or not!!!!:D
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
D2CAT is exactly correct. It hooks to the bucket to run the bucket level indicator that is attached to the right loader arm which when adjusted properly will indicate when the bucket is level. When set up like it should be is a handy thing to have. After you get it hooked back up there is a little procedure to adjust it correctly.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
316
284
catlettsburg, ky
Bucket level indicator. The hole just above the pin on your front end loader is where it hooks into.
The end of the rod should not be bent. It should be straight.:rolleyes:
beckmurph
Aug 23, 2012
316
284
catlettsburg, ky
IF you go to Kubota.com Parts for the B2650 and look at the local options for the lA535 loader you will see the parts you have lost
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
To further explain the level indicator, when you get it fixed it should be adjusted to indicate when the bottom of the bucket is level when on the ground. When you are picking up material off the ground like gravel, sand, mulch, dirt.... it helps the have the bottom of the bucket flat on the ground. On most tractors it is hard to tell if the bucket is level from the seat. If you do a search on level indicators you can find some additional information.;)
