BX2537A Sweeper
Knott
2015 BX2670-1, BX2755HD Snow Blower, Farmking 4' box Blade, BX 2760A Plow Blade
Jun 2, 2015
101
Manitoba
Well I got the chance to try out my new BX2537A sweeper. WOW does it work. I swept the gravel our of the grass that the snow plow pushes down into my lawn every year. It used to take 2 days to rake out the gravel by hand, now it took 40 minuets with this sweeper. You do want the wind behind you when using this unit. I was lucky the wind was from behind & to the left. Much better for the lawn mower blades to remove the gravel from the grass.
Here is a short vid.
https://youtu.be/kPU7u0-T684
3,017
I used one of those before on a bobcat.....well the wind was not my friend! I looked like a raccoon! I took my glasses and mask off and I was covered from head to toe in dirt and gunk!
Looks like that did a great job and the wind was your friend!;)
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
I was thinking of buying one of these. Does it also remove that and the leftover fall leaves, that didn't get picked up in the fall?
Sent from my Z850 using Tapatalk
wiltff
L3800 HST & FEL. 66" LP Tiller, 72" EA Boxblade, 84" Woods disc, 96" rake
Aug 6, 2016
Milwaukee, WI
Looks like it works as a great dethatcher as well. Sucks to be your neighbors.
Knott
Jun 2, 2015
101
Manitoba
Just removing gravel.
There are no neighbours, l live in the country.
It is great for leaves you just have to set it 1.5" above the ground & it is great. It doesn't tear up the grass at all.
rkuszmar
BX2370 with FEL and MMM.
Mar 1, 2017
12
Middleton, MA
Resurrecting this post. Any chance you have the operators manual you could share digitally? I just picked one up used and I do not have the manual. I want to thoroughly go through it before I use it. It is a little beat.
