BX25 Max Tongue Weight on 3pt. Hitch?
dom
Kobito BX25D
Feb 18, 2014
62
Front Royal, VA
Hi folks.
Just got a 28" Airstream and want to move it back and forth in the yard more easily. Tongue weight is 670lbs. Wondering if you all think the BX25 can do it?
Thank you!
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
If I read that table correctly, W1 is the max weight you can put on the 3pt hitch, and is shown on the next page. The weight in their picture is probably on the draw bar, and is 550 lbs. The max weight of the load being pulled is 1765 lbs. I am guessing the Airstream weighs more than that. Pulling a heavy weight on the 3 pt hitch of any tractor is risky if a slope is involved.
twomany
B7200
Jul 10, 2017
793
138
Vermont
Hook to the draw bar, NOT the three point lift.
700# there should be just more traction ;-)
But pay attention of the pull load. As mentioned, hills can kill you if the tractor rears or slides.
(And that is when the draw bar shines and the 3pt is lacking.)
2,863
WHAT he said ^^^^^^^^^^^^^^^^^^^^^^
Never use the 3 point for something like that.......
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
As above.... Be Careful.
I use my BX to move my boat all the time. It can be up around 5000 lb when there is fuel, water, and the rest of the junk in it. (anchor, vests, water toys, so on) I only move it in low range, and I make sure it's in 4wd and the FEL is on. You need to use 4wd since you brake is in the trans, and not on the wheels. In 2wd, it's too easy to slip a tire, and have it feel like there's no brakes at all.
With that said... only try to move a heavy trailer on flat ground !!!! It can get ugly FAST if you are trying to move it on a hill.
Oh... on last thing... since it's a big trailer, and I will assume you have electric brakes on it... make sure you put the trailer brakes on a long pull cord so you can yank the emergency switch out if need be.
https://goo.gl/photos/YRtFaiUun4KLUtrK7
dom
Kobito BX25D
Feb 18, 2014
62
Front Royal, VA
Trailer is 6,000lbs. Only looking to move it into a corner off my driveway. The maneuver is too tight for my dually. Looking to move it about 15 feet, but will require a bit of back and forth.
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
Lovells, Mi
Another option, mount a receiver on the front. You have a better view of the trailer while moving. You will want a ballast weight in back (about 420 lbs) with that much weight on the front, and as already mentioned in 4wd at least if not on pavement.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
As others have said, I would not attempt to move that trailer on ANY incline. I move my trailer with my L4060 on flat ground for convenience, but I find it difficult because all I see is the flat front face of the trailer (zero side view).
