I am fabricating a trailer hitch assembly to install on the front of the BX25. It will be mounted via the same holes used to mount the front bush guard.
I want to use the BX to put 2 jest skis in the lake at the summer home. They are 4 stroke machines and the weight with the trailer is approximately 2000 to 2200 lbs. I will be running down grade a little to the lake and will need to reverse to remove them. I am thinking that low range 4wd should be sufficient for this.
What are your opinions on using this machine for this sort of thing. Can it handle the weight?
thanks
Jim
thanks
Jim
