BX 2630 shaky start/stop
MEDIACLIFF
L5030 BX2360
Jul 26, 2022
Clarkesvillle GA
Just picked up a 2010 BX 2360, 400-hrs, runs like a top once it's started. Starts easily... but shakes hard when starting and when it is shut off. All fluids have been changed. Added some TriboTex and it idles and runs very smoothly. But, shakes violently as it's started for about 1-sec. Odd...????
Any ideas would be highly appreciated!
Thanks,
Cliff
#40Fan
252
140
It's a 3 cylinder diesel. It is going to shake a bit.
Might look over the motor mounts and make sure they haven't disintegrated.
5,130
933
To help us evaluate your "shakes hard," could you please tell us about your experience with diesels.
Is this your first or one in a long string of them.
Diesels operate with a much higher cylinder compression than gas engines and this fact alone will make any diesel operate differently than a gas engine when starting and also stopping.
This article, while dealing with gas engines, will enlighten you about primary and secondary balance forces within various engine designs.
Engine balance
hodge
Nov 19, 2010
2,859
369
Love, VA
Thank you! Will check the mounts. Runs smooth as glass once started, though.
They are high compression engines. It is normal to shake momentarily when started and shut off.
2,387
On my BX2200 this is referred to as the death rattle on shutdown. Normal, I would say, for a BX…
On start up I guess mine may initially shake a bit, but much less than on shutdown. So I do not really notice.
ve9aa
Apr 11, 2021
1,202
975
NB, Canada
My TG1860 (3cyl diesel, slightly smaller than a BX engine) shakes on startup/shutdown like a cr@ck wh0re having withdrawl from some illicit substa@nces.
Has for 17yrs.
My nearly new BX shakes less, but still shimmy's/shakes a little bit.
MEDIACLIFF
L5030 BX2360
Jul 26, 2022
Clarkesvillle GA
Engine balance
Hi Dave,
Thank you for your response!
I have an L5030 & a Gator which both start quickly and smoothly. So, I am fairly familiar with diesels. But, this one shakes the whole front of the tractor. It does seem to be compression related... but surprisingly so!
Motor mounts seem solid, but need to take the front end off to see them clearly.
Thanks,
Cliff
5,130
933
Hi Dave,
Thanks,
Cliff
Cliff
I would troll dealer lots looking for the same model and then see how it compares.
JerryMT
Kubota M4500, NH TD95D,Ford 4610
Jun 17, 2017
528
156
The Palouse - North Idaho
Thanks,
Cliff
Are you using the glow plugs when starting? If you are, are your glow plugs functioning? Starting an indirect injection diesel without th glow plugs usually involves either a non-starting situation or a raggedy start, i.e. lots of shaking, smoking, etc.
4,065
I have a BX2360. Had it 9 years since new.
Shook on start up and shut down all 9 years. Inherent to a BX of any vintage.
Daylight
BX231, Ortolan T10
Feb 25, 2021
263
365
+1
My BX231 shakes at the moment of starting, for a second of so. Completely normal.
Has for 17yrs.
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
167
54
Mill Spring, NC, US
My BX1870 and my neighbors new er BX??? both do the same. Start up and shut down. Doesn't matter if we use the glow plugs when starting.
I think it has to do with the engine in the BX's being rubber mounted.
3,248
X5. I went thru several air filter brackets when I had the BX for this very reason. So many, that I simply gave up replacing them and just used a bungee to strap the vibrating air filter housing. ;)
Your observation is completely normal.
