Bush hog almost stalled engine
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
322
27
23
Mobile, AL
Twice yesterday my bush hog bogged down and the tractor engine almost stalled. I lifted the cutter and the engine recovered. I was transitioning from thin grass and backed into some very thick, heavy bladed grass. The cutter was low to the ground and I realize now I should have raised the cutter before backing into the thick stuff.
The PTO suddenly slowing the engine down can't be good. Is it likely I messed something up?
markbxr400
L3901, LA525, RC1860, SCR0660, BB1260
May 19, 2018
56
Magnolia Springs, aL
My L3901 does the same thing.
If I am moving steadily into different grasses, I'll bog it down. I either raise the blade to recover, stop, or push in on the clutch to let it have time to recover.
I have a clutch on mine, that is adjusted. It usually does't slip in these situations where the change in load is relatively gradual. It does immediately slip if I slam the blade somehow, eg, hit a hump in the ground, etc.
3,020
What is your engine rpm when this happened?
rademamj
Waco, Texas, USA
That is 100% normal behavior from a rotary cutter. You can always increase RPM when transitioning into higher field grass. Also, if this first time you have cut the field, briefly walk the high grass looking out for any debris: such as barb wire, old fence posts, any metal. This will help prevent problems during cutting.
Sent from my SM-G930V using Tapatalk
mickeyd
Mar 21, 2014
1,192
Guin, AL
I have experienced the same thing on my L3200 when I first get into high weeds. I have a slip clutch on my cutter but as Mark said, it normally only slips when hitting something more solid.
7,503
That advise may take a few minutes but it will save a fortune over time if followed!
Yep, wrap some wire around your mower, or hit some of the junk the oil field guys leave, or a T post and your daily output changes quickly.
Run your tractor into a hole some critter made and you may need a new front end on your tractor. Or, you could roll your tractor if you hit such a hole on the side of a slope.
259gibbs
US
You never mention how many HP on the tractor And how big is your Bush hog, the rule is 5HP per foot. My never bogged down with 30 and 5 feet bush hog, cutting high set at 3 " tall. The grass was belly high.
Sent from my SM-G965U using Tapatalk
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
I've stalled my bushhog a couple times. I mow slow and rpm at 2000. It does give you a jolt when it stalls though.
SDT
Apr 15, 2018
3,627
1,354
That happens, but it hurts nothing.
SDT
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
My 5’ hog used to STOP my Iseki when I hit a rut. Talk about exciting!
No big deal now with my B2710. I keep my RH on the 3PH and pull up when it bogs. You could also push in the clutch quick when things go awry.
markbxr400
May 19, 2018
56
I run mine at PTO speed (abut 2500 rpm). I have the HST transmission, mow in Mid gear, and if I start to sense the tractor automatically slowing down (bogging down), I just get off the gas a little. I try to catch it before it goes below 2000 rpm, even sometimes having to stop entirely. I've been out of town for about 5-6 weeks, and we've had a ton of rain and a hurricane here in lower Alabama, so my 34 acres is overgrown. Started mowing it today. Slow going . . .
bambam31
Apr 3, 2014
322
27
23
Mobile, AL
I fell better about it now. I usually mow slow but I may have backed in kind of quickly into the thick grass too. As always, thanks for the responses.
