Bucket working slow
stapleton32
Edinburgh, In
Please help me out here guys, I have a Kubota 2710 and the bucket works at a slow rate and is jumpy. I changed hydraulic fluid and the same results. I warm it up and its a little better but still not up to performance the back pto works great just the front loader that don't seem to be working as quick as it use too.
Kricks Lil Ox
B2710 w loader, RMF72 bushhog, 5ft blower, blade
May 5, 2014
Penna USA
I've got a similar problem.
Two items recommended to me:
check - quick-connect hydraulic connectors (at dentent/control valve) as they may be dirty,
and seals in pistons may need replacing (this is more related to poor lift/down pressure).
rentthis
998
21
summerville,sc
Can you hear unusual hydraulic whine? If so, you may have to reset the limit on your 3 point hitch lift lever. If it goes up to far, it will deadhead the hydraulics and cause the rest of the hydraulic system to act peculiar. Just lower the lever until the whine stops.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
First thing I thought is air in the system.
Does the hyd fluid look milky like it's full of air bubbles?
You could have a split in the rubber boot on the suction line.
