Bucket blade
scottz
1988 L2550DT-GST 2001 BX2200D HST 2016 L2501 HST
Nov 27, 2015
60
Colorado
My L2550 has an Ameriquip FEL with a 5' bucket but the bolt-on bucket cutting edge is missing. I don't plan on a lot of scraping, just moving gravel and stuff. Should I get a blade for the bucket? Where would I find something like that?
Thanks
9,292
A lot of buckets have holes in them, it's not for a bolt on cutting edge, it's for bolt on teeth.
If you look under the bucket and it has skids pads / strips on it then putting a cutting edge on it will cause the bucket to want to tilt back thus causing the cutting edge not to squarely sit on the ground. ;)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
If you want to install a cutting edge go by Bobcat, Cat or ect and let them measure your bucket to see if they have a edge that will match your bucket. A factory edge will last a long time or if you really want a good aftermarket look at a ESCO brand edge. ESCO will cost more but you'll never wear it out.
