Box Blade Build
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Over here a box blade is a new concept so I'm trying to design one. I've found a couple of fab shops that can do it "if" they have plans. I've found some plans and pics but I'm not sure what size my tractor will handle. Ideally it would be about 4ft in width as that's about the wheel-width of my tractor. HELP!
Tooljunkie
May 13, 2014
4,150
I think matching the width is the best thing you can do,the rippers may be where you run into issues. But they can be adjusted to keep from going too deep. As well,when the box is full it might be a little much for tractor. That being said, my l1501 2wd will pull a 6'back blade heaped with gravel. I also plan on buying or building a box scraper this summer. As well as a power rake (harley rake)may combine the two.
8,831
50" to 52" would be as wide as I would go.
Keep the aprons (side boards) about 1/4" above the blade.
Good sharp curved blade is the key to making it work well.
Tomcat
Nov 19, 2014
557
Thailand
That's the main issue I'm having. I don't think I'll be able to come up with a curved blade. I really need to get this done before the monsoon season starts (April).
8,264
My dad needed a piece with a slight curve for a repair. He threw a piece of flat stock out in the parking lot and ran over it with a vibrating roller :D Course he worked for a paving company at the time :rolleyes:
Have you asked your local fab shop if they had a way to curve a piece of flat stock. I'm sure you wouldn't be the first person there with a need for it. Even if they supported one end on blocks and then run over it with a large fork lift, it would put a curve in it. Problem though is you would have to use a whole sheet and take what you need where ever the curve developed :rolleyes:
8,831
Daren,
What your talking about is the whole backing plate be curved like yours is, surprisingly you don't really need for that to be curved for it to work right, just the blade needs to be curved.
8,264
Daren,
I knew he was talking about the cutting edge's :p:p my point was if the fab shop didn't have a press that could put a slight bend to a piece for the edge. they could put a red neck bend in sheet of flat stock and take what they need out of the bend for it :p:D:D:p:)
8,831
I have sheets of 1/2 AR500 steel here that would do the job perfectly, but I don't think a D9 cat could bend that stuff! :D
I bought a curved cutting edge off EBay last year that I think only ran me $100, the issue being that to get it to Thailand would cost a mint.
How far are you from India?
That's where all that steel is being made now.
Corney
L1500DT, front end loader, mower, tiller, snow blower
A curved cutting edge is enough to get the material rolling ahead in a blade box? I am used to the tilt on a Cat 140 G grader curved blade to keep material rolling to fill low spots and cut out high spots.
That is how I grade even with my three point hitch back blade.
Tomcat
Nov 19, 2014
557
Thailand
Maybe I could have the shop use an angled piece of flat stock instead of the curved black piece as shown in Wolfman's pic.
8,831
Yes that is how a back blade works, just like a grader blade.
A box blade works a little different, it just traps material then drops it in the lows.
6,691
TC, might go back to that salvage place you showed a few weeks back and see what they may have to start your fabrication with.
Tomcat
Nov 19, 2014
557
Thailand
I did that last Sunday. They had two blades in the yard - a new one and another that looked like it came off a D9! :eek:
Tomcat
Nov 19, 2014
557
Thailand
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I don't think the cutting edge necessarily has to be curved, but it does need to be sharp in order to peel. I'd consider a replaceable piece of flat bar of ~1/2" or so thick that is back beveled to create the cutting edge, similar to an old fashioned hand plane.
OldeEnglish
Jul 13, 2014
766
Western, MA
Sounds like you could really use a FEL too!
A metal fab shop should be able to make you a blade for the box with a press beak or a roller.... I would think any fab shop has one or both that are at least 4' wide :confused:
Tomcat
Nov 19, 2014
557
Thailand
That's sort of what I had in mind.
