bolts holding the mower blades on?
4,050
OK I got 1 1/4 to big, 1 1/8 to small,, yeah I know 1 3/16 right,, nope it almost fits but is sloppy,, I hate using an adjustable wrench on things if I don't have to,, soo is this thing a metric or what??
Orange Tractors
L175 w/Woods L59, Allis Chalmers WD
Jul 19, 2009
323
Butler, MO
Try a 30mm socket.
Robert
Stumpy
L175
Dec 1, 2011
848
NE Ohio
That oughta be 30mm. 1-1/8 is about 28.5mm and 1-1/4 is 31.75mm. I'd be surprised to find a 29mm nut.
A 1-3/16 is only 0.006 larger than 30mm, it should work fine. If you can measure the nut. It's possible your socket is worn out but I wouldn't think something that big sees a lot of use.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
I change probably hundreds of them per year and have always used a 1-3/16 socket! BTW proper torque and good belville washers are very important!
4,050
And what would the torque be for them little buggers?
Stubbyie
879
Midcontinent
Deck or floor pan on L35 retained by 29-mm bolts.
Sunk down into holes sized juuuuuust right for proper socket.
Odd but occasionally used.
OrangeLivin
75
Eastern
Yeah it was a zombie post but you know what, it was perfect timing for me, considering I'll be pulling the blades off the deck tomorrow. Thanks for the info (old as it may be) everyone! :D
3,445
Unless you tried the same cheap way I did….with a BETSTCO ”Farmers-Hand” finish mower….. you’ll find them to be a 14mm LEFT HAND THREAD 🤬 and a 24MM hex.
An impact quickly destroyed it…and Fastenal wants several Dollar$ Each…. and only sells them in bags of One-Hundred. :mad:
(It was on a weekend and I temporarily resolved it on ebarf…and ordered replacements from Betstco.)
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
995
1,343
Pittsburgh
Hmph.
Seems like a necromancer convention in here and my e-vite got lost in the mail.
:unsure:
Cake Farts
Kubota Z422 and L3302
Jul 3, 2024
Kansas City
THAT'S WHAT SHE SAID!
Seriously? So, so, so disappointed that no one took advantage of this in 2013. I mean... I came here via Google search and was amazed to see the zombie post alive.
Pepsiboy
BX2350D, FEL, MMM, Rear tiller, back blade
Oct 3, 2014
171
Shell Knob, Mo
Skeets, I use the 1 3/16 on my 54" MMM deck blades under my BX. It fits just fine. I use breaker bar to remove and torque wrench to tighten to 75 ft/lbs. Haven't had any problems in 16 years of doing that.
