I'm very new to hydrualics-first tractor with hydraulics.
Finally got my new-to-me snow plow hooked up and within two minutes had oil all over the garage.
Had the tractor at half throttle and was checking the 4-way plow for movement (luckily nothing binded). When I picked the blade all the way up to max lift the valve broke off the front of the 4-way controller. I don't fully understand the inner-workings of the valve so I'm not sure how to troubleshoot it.
One observation-the up/down portion is controlled by the lever closest to the tractor-that was the function I was operating when it blew. The valve that blew is off the side-to-side function which I was NOT operating?
I'm sure I can fix it but I'm focused on better understanding why this happened. I just don't want it to happen again after I fix it.
Also, are these universal hydraulic components that I can get at most stores?
Thanks in advance for you help
