Blowing Main ECU Fuse
trucker14
L3901HST
Jan 25, 2019
Blasdell
My L3901HST is blowing the 5 amp fuse from the ignition to the Main ECU when I let up on the speed control pedal. Makes me think its the acceleration sensor, but why would it blow when I let up on the pedal instead of pressing down? Do you think it is the sensor or the ECU? This started when I started getting an E 20 code. I think I have that fixed since it isn't showing up anymore when I turn the key.
200mph
Mar 3, 2017
1,228
65
PA
Maybe the the pedal/linkage is hitting the wiring harness and causing the wire to short.
Might want to consider using a circuit breaker while trouble shooting the situation.
mikeinAiken
L3901HST,BH77, LA525, 4 in 1 bucket, grapple, tiller,boxblade
Nov 11, 2019
Aiken, Sout carolina
Did you ever find out what caused this failure? I have about 500 hours on my L3901HST and have the same failure. The 5 Amp ECM fuse blows when I release the HST from forward.
9,621
You more than likely have a bad HST switch. ;)
pghponton
L3301 w/LA765 FEL
Jun 29, 2016
Salem Twp, PA
HELP!!! Where is this HST switch located??? I am having the same issue and want to test the resistance but I can't find it. Somebody please help me, getting frustrated. Thanks in advance.
Chanceywd
Mar 26, 2021
744
687
central ny
Isn't the L3901 the same chassis as The L2501? My manual says it is located in the steering column support area.
