Blowing Main ECU Fuse
trucker14
L3901HST
Jan 25, 2019
Blasdell
My L3901HST is blowing the 5 amp fuse from the ignition to the Main ECU when I let up on the speed control pedal. Makes me think its the acceleration sensor, but why would it blow when I let up on the pedal instead of pressing down? Do you think it is the sensor or the ECU? This started when I started getting an E 20 code. I think I have that fixed since it isn't showing up anymore when I turn the key.
200mph
Mar 3, 2017
1,228
59
PA
Maybe the the pedal/linkage is hitting the wiring harness and causing the wire to short.
Might want to consider using a circuit breaker while trouble shooting the situation.
mikeinAiken
L3901HST,BH77, LA525, 4 in 1 bucket, grapple, tiller,boxblade
Nov 11, 2019
Aiken, Sout carolina
Did you ever find out what caused this failure? I have about 500 hours on my L3901HST and have the same failure. The 5 Amp ECM fuse blows when I release the HST from forward.
5,125
You more than likely have a bad HST switch. ;)
pghponton
L3301 w/LA765 FEL
Jun 29, 2016
Salem Twp, PA
HELP!!! Where is this HST switch located??? I am having the same issue and want to test the resistance but I can't find it. Somebody please help me, getting frustrated. Thanks in advance.
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
564
401
central ny
Isn't the L3901 the same chassis as The L2501? My manual says it is located in the steering column support area.
