Spray cooking oil on the inside of your chute. It'll help immensely !Any advice on dealing with clogging?
Good advice...wet snow really sucks. Go a little slower and keep her turned up.Spray cooking oil on the inside of your chute. It'll help immensely !
It is wet - first year with it so I do not know the correct RPM. What would it be?Are you running at correct pto rpm and is this very wet snow?
I believe your rpm should be 2550 for the pto. Should be marked on your speedo.It is wet - first year with it so I do not know the correct RPM. What would it be?
That's really getting up there on the rpm's. With my L3800 @ 540 it has no problem throwing snow. Maybe just the blower? Also when you ingage the pto I keep my tractor at an idle and then after it's ingaged I turn up the rpm's...never had a problem with shear pins.I had a Bervac on my 1980 B7100 & at 540 RPM it worked like crap! The 2nd stage had only 3 blades on the impeller vs. 4, & they might have been worn down at the tips. To really throw snow I used the 2nd PTO speed (750,800 RPM?), & it worked great. Only downside was at that PTO speed, I had to release the clutch easily - If clutch engaged too quickly it would snap the shear pin. My buddy (who I bought the tractor from) had the same blower & uses it on his newer Kioti @ 540 RPM - same deal, works poor.
