Block heater for 2370
2pats2
B6100D,snow blower,rear blade,belly mower,dozer blade and rear ender buckket
Jan 26, 2010
25
Gibsonia,Penna.
I am trying to find a screw in type block heater for my 2370 . I do not want to remove a freeze plug to install one as the dealer has offered . Doe`s anyone have any information that can help me .
Thanks for any information .
patnpat (at) zoominternet (dot) net
2,737
joesco
Hampstead, NH
Pat,
There is no other choice as to a screw in on this model. Removing the freeze plug is the only method for the block mount. And this is a bulletproof method - if done correctly there are no problems. Why do you not like this idea from the dealer?:)
You could cut the lower radiator hose and install one of these :
https://www.etrailer.com/Vehicle-He...com/Vehicle-Heaters/Kats-Heaters/KH16500.html
Last month I installed a block heater in my BX2230 in the forward positioned freeze plug after returning the hose (coolant) heater unit to the dealer.
I've been a fan of block heaters, living in NH for 35 years. I plug it in for 2 hours and it starts like it's July! So much less stress on the engine and operator!
It took 15 minutes to install and 10 of those minutes were knocking out the freeze plug, draining the coolant and cleaning the port and area with Acertone.
Applied some loc-tite and used a 1" socket to install and seat it.
Sent from my Lenovo TB-8504F using Tapatalk
8,284
Most Kubota engines do not have a provision for a screw in type Block heater thus the need for a drive in model, all of mine have those and they are fine and dandy, never had a problem with a single install or use. ;)
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
My BX2670-1 took a screw in type block heater but my BX23S is a freezep plug installation. Probably the same for your 2370.
Sent from my SM-N920V using Tapatalk
200mph
Mar 3, 2017
1,228
61
PA
It looks like your BX2370 requires 70000-00771 block heater from what I found.
BLOCK HEATERS
70000-00771 Block Heater for BX2350, BX2360, BX2370, BX24, BX25, BX25D/-1
70000-73274 Block Heater for BX2660, BX2670/-1
70000-00298 Block Heater for BX1850, BX1860, BX1870/-1
It looks like this is a freeze plug design and not the desired threaded type.
http://www.messicks.com/part/70000-00771/block-heater-kit
2pats2
Jan 26, 2010
25
Gibsonia,Penna.
Thank you for the reply . I thought if there was a screw in type and you could avoid tampering with a freeze plug you would eliminate a possible leak in the future . I keep coming up with this answer so I guess this is the only way to go .
2pats2
Jan 26, 2010
25
Gibsonia,Penna.
Thank you . I hope my instillation goes as smoothly as yours .
2pats2
Jan 26, 2010
25
Gibsonia,Penna.
Thank`s to everyone for your helpful reply's . I see a bunch of them on e-bay so I will go ahead and order the 70000-0071 ...............
