big agri rubber on a b6000.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
just a quick one guys.
on the b6000 i,ve got 6-12 ags on the front, will 12.4 -16 be too big for the rears, if so , is it the height or the width or both.
thanks.
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
thanks.
I don't know the answer. BUT is your tractor 4WD? If so, as was mentioned somewhere in this forum, what you do to the back you will have to do to the front. The tire diameter ratio's have to be the same.
If it's 2WD then the only concerns would be, as you mentioned, clearence AND power from the engine to turn bigger tires under load could be an issue.
If you're plowing a field in low gear now with just the right amount of power to keep her going then those bigger tires will not do it for you.
Though, you will hall ass in high gear without any load.
Scott
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
thanks.
Well this is what I have seen.
Front: 4 - 9
Rear: 7 - 16
Anything over and under might stress tractor.
Will
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
Nawh its an oddball tire size and a pain in the ass to find new to replace them. So I had memorized the size so where ever I went looking for rubbers I knew what I needed.
