Ballast ?
Onekawboy
B2601 w/ 3rd function and Chinese 1 ton mini ex.
Dec 15, 2025
27
11
Central Illinois
Wondering if anyone has filled there LX rear tires
14x17.5 with ballast trying to get a solid (close to accurate) number of gallons per tire … i have figured about 48 gallons i’ll need which is 23-24 gal per tire
6,926
3,024
I would - game changer. Hard part is deciding what fluid and what to spend on said fluid.
24 gallons is spot on btw
3,024
wind shield washer fluid is cheaper and is close in weight to the RV antifreeze for what its worth.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
747
747
Amsterdam, NY
Here's a lbs. / gal comparison to estimate weight added.
Lbs. / Gal Fluid
6.50 Methanal Alcohol
7.60 Windshield Fluid
8.33 Water
9.60 Antifreeze
10.85 Beat Juice
11.60 Calcium Chloride
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,893
2,305
Western MT
Do consider the toxicity of the fluid both to the wheel and the environment if you get a flat.
For me, Rim Guard (Beet Juice) was the best choice. Dealers also will come to you to fill your tires in some areas.
