Back blades & snow - - - lessons learned ?
Steamer Pete
LX2610
Mar 29, 2021
49
42
Holland, MI
Greetings all ! Proud owner of an LX2610 this past Spring to help around the new house in the woods. Living in central western Michigan, and got our first real taste of snow this weekend. Most of my 1300 driveway is gravel and "earth". I'm waiting for the ground to freeze to reduce pulling up any dirt, but I did plow today's 6" of snow this evening.
My blade is a 6' LandPride. I bought the shoes to keep the cutting edge off the ground. I am also considering adding a piece of 1-1/2" pipe to the cutting edge to reduce the digging effect into the dirt. I know pick-up snow plow drivers do this to prevent peeling up lawns. Anyone else do this trick with any success?
Anyone put some form of slippery coating on the blade surface to shed the snow?
Any other neat thing you do to make your back blade perform well in the snow ?
Thanx all !
JWool
B2650HSDC FEL & Front Snow Blower, ZT-Z421, GL11000 Generator
Dec 29, 2013
97
17
Northern MI
I changed the cutting edge to a UHMW plastic edge like this.
W plasic
WAS BANNED FOR NSFW PICS
5,161
number two
B3030HSDC L2501HST
Mar 26, 2021
393
182
Northern Lower Michigan
Plow pipes are the norm here for the plow guys.
I turn my 6 foot blade backwards when the gravel is unfrozen like now.
Usually takes a few snows until I can use the front blower.
Every snow season is different!
Good Luck!
jyoutz
Jan 14, 2019
3,494
2,581
Edgewood, New Mexico
If the snow is deep, I take one pass with the blade held 2” above the gravel, then turn the blade around and float it on the gravel. If the snow isn’t deep, I just turn the blade around and float it. I haven’t found a need to change or add anything to the cutting edge.
IanB
LX2620, LA535 FEL, B2781A-63 snowblower
Aug 31, 2021
24
Manitoba
It's not installed yet, but after reading some similar threads I've picked up a 5x7x3/4" "horse stall mat", which I intend to cut a couple 12" strips off (1x7x3/4") and I'm going to sandwich it between my rear blade and the cutting edge so it hangs down 4" or so, and fold back under the blade, acting as a big squeegee so my gravel stays put and I get a nice smooth finish.
jyoutz
Jan 14, 2019
3,494
2,581
Reversing the blade will do the same thing.
JWool
Dec 29, 2013
97
17
Northern MI
Does the plastic cutting edge require special hardware to install, and where did you purchase the cutting edge from. I know that Kubota offers them, but wasn't sure if you might have found a less expensive supplier.
I used the same hardware.
This would probably work fine.
Jchonline
599
Red Feather Lakes, CO
Yes reverse cutting edge float is the key early in the snow season.
