b8200 hydraulic block
11,199
Yep that look to be the factory power beyond loop, could be used for the BH or Trencher option.
twomany
B7200
Jul 10, 2017
793
139
Vermont
Is that PB fitting available from Kubots spares?
It must be something a bit special to have an out flow concentric with an in flow.
Might be a fun piece to machine. ;-)
11,199
Yep it's a very odd fitting, I wouldn't want to have to replace it, they are very hard to find.
twomany
B7200
Jul 10, 2017
793
139
Vermont
I just did a quick napkin sketch of a fitting/adaptor that would work. (no dimensions)
Two o-ring grooves, an external BSSP thread and an internal O-ring boss does the adaptation. Add a few crush washers. Viola! All on hex stock if I can find it.
All based on the original banjo fitting to the lift. With the addition of an "out" port to supply the PB valve. ;-)
I'm going to run the thread dimensions and come up with the final part. It seems like a perfect match to adding remotes ..... ;-)
11,199
It would be far simpler and cheaper to just tap into the block that's made to tap the hydraulics just ahead of it. ;)
