I recently purchased a ‘89 B7200 with a 1640A loader. The tractor has 630 hours, and appears to be in pretty nice shape. However, I have a small hydraulic leak coming from the valve body directly in front of the brake pedal. A photo of the valve body is attached. This appears to be a divertor valve for when the loader is removed. The leak is coming from the stem which goes thru the valve body, and is held in place with a snap ring. I assume there are o-rings on the stem which is bad. Is this correct? Do I remove the snap ring and lift the stem out to replace the o-rings? Thanks for your help.
