B7200 hydraulic steering
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
831
1,550
Baranduda, Victoria, Australia
I have some more questions....
Is it better to tap into the existing hydraulics to feed the new steering pump, or better to use a separate reservoir and filter ?
If I keep the systems separate, is a spin on style filter (see below) in the return line to the reservoir a good choice, or is there something better ?
If I buy or make a separate reservoir, is bigger better ? My thinking is that a greater volume of oil and larger reservoir surface area will help with cooling.
Many thanks.
7,377
Many thanks.
You have 4 gallons in the sump and a 4 GPM pump on the tractor. Significant head room there. What size PS pump are you contemplating? i would think pretty smsll.
A suction side screen and return side filter would be optimal and an improvenent over OEM.
Paul Allwood
Jul 8, 2025
831
1,550
Thanks Dan.
When I get to the shed today I'll see if I can work out where to tap in for supply and return lines.
The pump I've bought is 4.9 ml/rev. So 12.2 l/min, 3.2 GPM at 2500 rpm. That gives me 1.9 GPM at 1500 rpm - the tractor isn't much use below that.
Are you saying that the filter I've pictured above would be suitable for the return side ?
Suction side screen - is that something that would be fitted into the suction line to the new pump ?
7,377
Paul Allwood
Jul 8, 2025
831
1,550
Today I made the bits to mount the double-ended steering cylinder.
Retracted
Extended
Due to the larger diameter front tyres I fitted a while ago, space is pretty tight. The current long drag link only just fits....
....so fitting the steering cylinder, whether it's the one I'm using or if I was using the more standard type, will take some care.
Here's the new assembly somewhere near where it will end up.
Paul Allwood
Jul 8, 2025
831
1,550
It seems like such a normal thing that the first version of anything I make doesn't work. I don't know why I bother with it - may as make the version 1 bits, put them straight back in the scrap rack, and get started on version 2 (or 3, or 4....).
The original plan of mounting the double ended cylinder using a ball joint at the end of the tube I added was so close but I couldn't quite get it to fit. I'm aiming to have the pivot in line with the centreline of the cylinder to minimise any sideways force. With the side to side movement of the axle and the lock to lock movement of the front wheels something always seemed to hit. If I moved the pivot point to fix one problem I found another.
So version 2 it is. I mocked up some bits to try another idea, still aiming to pivot along the cylinder centerline. I had to make bits solid enough to try the idea and position it properly as there still isn't lots of spare room and it's next to impossible to just hold things in place well enough without good support.
This pivot allows left and right, and up and down movement with the force along the cylinder centerline.
Straight ahead
Full lock right
Full lock left
In each of these positions, and with the front axle tilted fully left and fully right, nothing hits. The closest is about 1/2" between the tyre tread and the cylinder rod - this is the same as with the existing standard long drag link fitted.
Next I'll make a proper version of this pivot.
Paul Allwood
Jul 8, 2025
831
1,550
I made good progress on a decent version of version 2 of the pivots for the "fixed" end of the hydraulic steering cylinder today. I used sealed bearings for all of the pivot points - no play, no greasing.
The inner bit pivots up and down as the front axle pivots up and down.
The outer bit will rotate left and right as the steering moves left and right.
If you've seen what I made to convert the first 2 levers of the loader valve to a single joystick lever, you might recognise this design. It's pretty much the same, just bigger.
Tomorrow I'll make the brackets that support the top and bottom bearings and bolt to the tractor.
