B7100 HST transmission fluid
demerson2
kubota B7100
Sep 7, 2010
mississippi
Just purchased a 92 B7100 hst 4x4 tractor. Changed the oil and filter...ready to change the transmission fluid/ hydraulic fluid...Stopped by O'reilly's to purchase and they had 3 different types...O'reilly's AW32....AW46... and another classified as 303....could someone help me with the type I need?...and also if you have a cross reference filter for trans.....like a FRAM maybe?...thanks
8,325
Your probably not going to find either the fluid or the HST filter at O'reilly's.
The fluid type is UDT... and no that does not mean universal.
2 other expectable fluids are New Holland hydraulic fluid and Mystic JT6 fluid.
The filter is a High pressure filter, not an ordinary oil filter type.
There are several places to get them online if you don't want to get them from a dealer.
Golden eagle direct
Messicks
CJN8
B2650HSD, LA534 FEL, Gearmore Box Blade, Bush Hog, Cimmeron Rake
Nov 16, 2013
122
San Diego, CA
I say don't skimp on fluids, go with kubota UDT or SUDT2. I believe it only takes about 4 gallons, savings would be minimal. 5 gallons of UDT will run you under a hundred dollars. Hydrostatic transmissions can be picky when it comes to fluid.
demerson2
kubota B7100
Sep 7, 2010
mississippi
Thanks for the info guys....I live in rural area and the kubota dealership is a good hike from me....I'll just get both of them there....good info....thanks again
MMudd
B7100 HST
Jun 3, 2014
Cnetral MO
Wix filter no is 51361 and napa gold is 1361 If I remember correct for the hydrostatic on a b7100HD.
demerson2
kubota B7100
Sep 7, 2010
mississippi
bought a bucket of Super S fluid at the Kubota dealership....their recommendation for that old of a tractor...good guys saving me a few bucks:D....also a Kubota filter...fluid looked like chocolate milk...HST operates MUCH better...Not sluggist and dragging:)
also for the record....couldn't break the back bolts that hold the back screen filters under the foot rest with a 3ft cheater bar...took the back tires off....put the socket on my harbor freight electric 1/2" impact driver($40 ten years ago) and it came right off....no problem what so ever....file that in your memory bank;)
pjespers
B7100HST-D RC60-71B Mower RB-60 Blade Phoenix T-40 Tiller
Aug 13, 2014
11
Plad, MO
The manual says to replace the fluid every 200 hours. I have about that, but the fluid is still crystal clear. Do I change it anyway?
8,325
Being that your running a 30 year old tractor I would say if it's clean just change the filters.
If you haven't done so yet go to Kubotabooks.com and download the OPS manual, the WSM manual, and the Parts manual.
Look closely as there is several manuals some are for the older B7100 and some are for the 2wd model.
pjespers
Aug 13, 2014
11
Plad, MO
Thanks. I have the books. I'll change the filter. I don't think I can remove the strainers for cleaning without spilling fluid all over.
I didn't mean to hijack this thread. Sorry.:eek:
chadlw
1991 B7100HST-D 4WD, Modern MFG. 42" Competitor Brush Hog
Jul 18, 2014
McLoud, OK
Just FYI - I recently bought a 91 B7100HST that wouldn't move because the suctions screens were sludged shut and the oil also looked like chocolate milk. I bought 3 filters from the dealer (and UDT) but went to Atwoods and bought a bucket of 303 for $25 and using that for my "flush fluid". I'll probably do two full flushes before switching to the UDT and new suction filters. I had a little metal in the old screens so wasn't sure what to expect. For a test with the 303 oil, I was able to haul my 16ft car hauler with small load of wood up a steep hill and the 3-point had no issues lifting it full height. I also want to stick a good magnet somewhere so I can keep an eye on pump wear.
2,744
Do as others have said, get the real stuff and DO NOT put a fram filter on there! AS Mr. Vic said in another post, the filter material matters - not to say that fram doenst make a good filter.....but get a Kubota filter and SUDT2 and see the difference. That ol commercial - pay now or pay later!!!!
6,382
85Hokie, "That ol commercial - pay now or pay later!!!!"
You better explain. There's a lot of folks here that weren't around then!
2,744
that ol commercial played forrreeeever !!!! I heard it in my sleep, but never gave it much thought , till it was MY dollar being spent on the auto....
From a 1970's television commercial for FRAM oil filters which showed a ruined car engine and a mechanic who quipped: "You can pay me now, or you can pay me later." :D
https://www.youtube.com/watch?v=OHug0AIhVoQ
sad thing is that fram has a bad rep when it comes to oil filters these days........:(
