B7100 engine oil capacity
Eise
B7100
Jun 25, 2018
38
Groningen, The Netherlands
I was changing the oil on my B7100, drained the old oil and put in 3.9 liters (4.1 qts) as per manual. I checked the dipstick and it was way overfilled, removed about a liter of oil and now it's filled to the top mark of the dipstick. But now is should only be filled with about 2.9 liters of oil (3 qts), which is significantly less that what the manual says.
Who can enlighten me as to what is going on here.
Eise
B7100
Jun 25, 2018
38
There was no water in the oil and it starts ok. I'm getting about 20-25 psi at idle. Are you thinking gunked up coolant/oil in the engine? Because I doubt that's the issue.
3,351
Check the rubber plug on the dipstick. It is not uncommon for the rubber to work loose from the metal rod, allowing the rod to slide up or down in relation to the engine.
Eise
B7100
Jun 25, 2018
38
Mine is still firmly stuck on the rod, I even compared it to a picture of a new one to see if the plug was is the right position. (It is)
I'm digging around the web a bit, and I seem to run into two different oil capacities for a B7100. One source says 3.9l (4.1 qts) and another says 3.1l (3.3 qts). That second one is pretty much what mine takes.. Is there a difference in capacity between older and newer models? Mine is a D750A, so maybe that's the issue?
DusterP94
G6200
Aug 25, 2018
Union City, IN, USA
I'm experiencing exactly the same issue with a G6200 HST. Service manual says 3.9L, but the dipstick reads a good 2 inches above the full mark. I've got a steady dribble of oil coming out of the blowby tube. I ordered a new valve cover gasket so I could check the baffle on the inside and it's fine. I even bought a new dip stick and it matches my old one exactly.
I'm honestly thinking of just filling it to the full mark on the stick regardless of what the manual says and seeing what happens.
2,928
Question about all the oil that comes out?
Ever measure the amount that came out? I typically have an empty container that I place the old oil into when finished.....I often find it is a bit lower that WHAT should go in!
So either the engine is burning it - possible, OR all of the oil is not getting out of the engine, and thus adding back 4 quarts or there about does place it over the line on dipstick!
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
My BX as many others I’ve seen are off also. My manual calls for 3.7 QTs and mine takes 4.5 and it’s still not right full.
faralta
B7500
Nov 1, 2018
Cincinnati
Is this the original engine? Seems to be a capacity change in the engine during the time B7100's were produced.
9,862
Yes there were several changes made in the B7100's life time.
On any model, go by the dipstick not the book! ;)
