b7100 3 Point Hitch kit ?
8,603
If you have the top arms already then that should set you right up.
hodge
Nov 19, 2010
2,945
509
Love, VA
I would buy a kit from Weavers- kit #W-7825-1112. The kit that you linked has bent lift arms- the B7100 uses straight arms. The bent arms may hit the tires, unless you move them out. Also, the lift arms should be 23 1/2" long.
www.compactractorparts.com
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
368
9
Homer City, Pa.
Buy yourself a Kubota 3 point set up, even if it is used for the 7100,
you'll be happier in the end.
Big Kahuna
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
Alberta
Big Kahuna
Yup. A classic case of you get what you pay for.
