B7000 won't drive when in gear
Anton Dorrestijn
Kubota L1501DT
Aug 21, 2016
Steenderen, Netherlands
I have a strange problem with my Kubota. When I push it really hard, it loses all driving and PTO power. I can put it into any gear, release the clutch, but it just won't drive and the PTO does not spin. When I wait a few hours, it will drive again and everything seems normal.
Where should I look to fix this problem. Any tips or tricks?
Thx!
Anton
2,754
Thx!
Anton
First guess would be a worn clutch, yet you are able to place it in gears w/o grinding. Something broken in the drivetrain would not "fix" itself as it cools down.
Adjust linkage in clutch, and see if any of that makes a difference.
8,377
You need to split it and replace the clutch disk, pressure plate, throw-out bearing and Pilot bushing.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Antoin: Assuming the guys are right about a clutch, here is a question. When you use this machine where is your left foot? The term "riding the clutch" might apply to you then. Also when shifting gears are you letting the clutch out so slowly that there is wear occurring? What tractor RPM when using the clutch? High RPM then can also can be a fault. With careful use of the clutch most tractors, cars and truck don't need any new clutch for a very long time. Operator habits can ruin it in a short time.
