B6200 4WD HST Creeps
Marengo
B6200HSTD 4WD, Land Pride FDR1548, Woods BR60, 4' Brush Hog, DIY 8'Yard Trailer
Jun 4, 2015
Marengo,Ohio
My old (1988) B6200 HST has been creeping for a while both forward and backwards, depending on the direction I was traveling when I released the pedal.
I've finally decided I need to resolve this issue.
The pedal is well lubed as is the whole tractor, like the old blues song says...it's cheaper to grease her.
I've been searching for answers to fix it but have not found the specific info for this tractor.
Any help is appreciated.
8,344
If the bearing (150) in the neutral adjust are out, will do it.
Also if the bushing (110) or other parts are worn, can do that.
A spring (030) missing or maladjusted tensioner (050) can do it.
Also if the Dampener is going bad can do it.
Marengo
Jun 4, 2015
Marengo,Ohio
Thanks Wolfman,
With over 3000 hrs on this tractor one or all of those items may need replaced.
Looks like I've got some digging around to do.
The WSM will be a huge help.
