B6100D hydraulic pump
Lyzic
Apr 16, 2022
32
Does anyone know if the high pressure out on the B6100D stock hydraulic pump is the top or the bottom line?
I can't find a manual for this tractor that tells me. I can pull them off and see but I'm hoping one of the gurus will know and save me a little bit of labour :)
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
I believe it is the one on the bottom of the pump. It will be the smaller diameter of the two pipes.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,936
2,437
WestTn/NoMs
There is a repair manual for this model at www.kubotabooks.com. It's an I&T, not genuine Kubota, but it should help you. It's in three parts, the hydraulics is in part 3. I've found these to not be 100% accurate, so double check when using it.
Assuming the manual is correct, this diagram shows the suction on top. You could verify with the parts diagram.
torch
Jun 10, 2016
2,884
1,130
Muskoka, Ont.
