B6100 oil pressure
4x4forks
kubota b6100
Sep 16, 2018
22
grendon underwood
After a recent purchase i have just replaced the cylinder head and got it running and noticed the oil light on at idle. Did a pressure test and basiclly non at idle and about 14psi at high revs. Did a bit of research and found out about the plug coming out of the end of the cam shaft. I stripped out the front and had to drop the front of the chassis down to get the timing gear cover off. Once off , No pug in the end of cam. Threaded and mad plug then welded as well. Will report on rebuild
3,090
well, you nailed the problem !!!!:D
Let us know how it goes! :)
4x4forks
kubota b6100
Sep 16, 2018
22
grendon underwood
Yes!!!!! Great success! Loads of oil pressure. The light actually stays off even after the engine is turned off for a short time and Hot. Around 55psi on the test gauge . Happy days :)
Gearloose
Kubota B6100, late 80s, FS850 rototiller.
Jan 17, 2022
San Diego County
I have had the same problem with my B6100. Started to disassemble the front end and noticed a complication. The PTO shat is so long that it appears that I must dismount the engine from the front frame to get the gear cover off. Is that so?
