edinottawa
B6000E, B6000DT, Massey Ferguson GC2300, Massey MF-14 x2, MF-16 x3, MF1650 x2
Will most likely apply to other machines as well. Occasional use B6000E, kept under cover and never left out in the rain. Used it one day and the next day the clutch was stuck, wouldn't release. Tried a few of the tricks listed here and on the web to release the clutch, no success. Finally made the decision to split the machine to see what's up. Dealer said just South of $1000 (Canadian) if all parts were needed so I decided to tackle this myself with a little professional help (mobile mechanic) despite never having split a tractor before now.
Pressure plate, clutch disc and flywheel were rusted together, and there were water droplets + rust stains on the flywheel. Also rust stains from water pooling at the bottom of the bell housing. I can only ascribe this to condensation since no flooding or rain events had been anywhere near this tractor, and the drain plug in the clutch bell was installed.
Mechanic said the flywheel, pressure plate, release fingers and disc were in excellent condition, just clean them up and reassemble. Pilot bushing was also in good nick. Throwout bearing was seized so I ordered the bearing and some other unrelated maintenance parts. OEM Bearing from Kubota dealer was $36 (CDN). Bell housing gasket is NLA so left in place.
Mechanic suggested that since this was a "rice paddy" tractor, that the drain plug wasn't necessary and leave it out. That would allow some air circulation in the bell housing.
Put it all back together and the little K is running like a Japanese watch.
See my other posting about changing that pesky fan belt.
Comments and questions welcomed.
